Old July 14th, 2012, 06:50 PM   #1 (permalink)
Doug Fir Neck Questions
These are for those of you who have made necks of it before. I am giving it my first go with doug fir, and I wanted to know how you finished them. Also, I am wanting to do a headstock that is more or less slotted like a classical, so do you think it would be strong enough to do a "hollow" headstock? It will be a tilt back type of thing. Any experiences/suggestions are welcome.
Ripthorn is offline   Reply With Quote
Old July 14th, 2012, 08:29 PM   #2 (permalink)
gatimberframer's Avatar
Personally I think Doug fir is too soft and too weak in shear to do a slotted headstock.
gatimberframer is offline   Reply With Quote
Old July 14th, 2012, 10:40 PM   #3 (permalink)
crazydave911's Avatar
First, the finish question. If you want a gloss finish and love the brightwork on wooden boats, then Helmsman Spar Urethane is second to none . Otherwise I'd use Tru-Oil, easy to apply and can get a nice gloss with a smooth satin finish if desired.
Second question, doug fir is very strong but with a slotted headstock grain orientation counts for alot as does rings per inch. Riftsawn or quatersawn would be the best and look for some old growth if possible. I wouldn't use anything less than 7 rings (growth rings) per inch on a big slotted headstock. Fir tends to somewhat brittle with new growth of wood of extreme age. Otherwise it should work fine.................I'd use it
Dave
My Facebook
Old July 14th, 2012, 11:45 PM   #4 (permalink)
I just completed this guitar last week. Nitrocellulose finish. Neck bowed forward a bit more than the maple and cherry necks I'm used to making. But it was nothing that the truss rod couldn't handle. I put a 2 way truss rod into it but I should have just gotten a cheaper 1 one truss rod because there's no way I'll ever need the forward adjustment. I love the way it looks and I've had it strung up for a week and it's playing great. I consider it a great success.
Irving is offline   Reply With Quote
