Old July 7th, 2012, 08:13 PM   #1 (permalink)
iocari's Avatar
8 piece blank???
i have 8 pieces of mahogony i have left over from other projects, together if glued they would be a perfect size for a body blank,
is this worth doing?
will all the gluing be too much?
would it be too weak? and if so would 1 piece top strengthen it?
Thoughts please.
it may be a way i could use up all my scraps
iocari is offline   Reply With Quote
Old July 7th, 2012, 08:25 PM   #2 (permalink)
I have seen many casters in here with more pieces than that.
Also my very first guitar is glued from 7 pieces of mahogany. I builded that (body only) as a youngster some twenty yers ago, and It`s still holds and sound very good.
If you get them glued up properly, I think it will be just fine:)
Good luck with your build :)
Warem is offline   Reply With Quote
Old July 7th, 2012, 08:33 PM   #3 (permalink)
Henry's Avatar
It'll be strong enough if you use a good adhesive. The bond is generally stronger than the parent material. Have a look at the "yardstick" build from this years Challenge or the "popsickle caster". I had these bits leftover after making a window. Now I have to finish the guitar after building the house the window went into.
ID:	133880   Click image for larger version
Mars needs guitars.
Henry is offline   Reply With Quote
Old July 7th, 2012, 08:52 PM   #4 (permalink)
Crafty Fox's Avatar
It can be a great way to use up the precious scraps of wood. My Harlequaster is 73 individual pieces, plus Rosewood/Maple/Rosewood stringers between each piece. I think it's over 300 piece top; too many for me to count!
Crafty Fox is online now   Reply With Quote
Old July 7th, 2012, 09:20 PM   #5 (permalink)
guitarbuilder's Avatar
My pickup test body in the " let's make a pickup" thread is about 12 pieces of pine and it is hollowed out for pickups all the way through. My 2009 challenge guitar was too. No problems.. I make sure I use a scraper on the glue faces to get rid of any raised knife marks that may impact a good bond. Use a good yellow glue too.
Old July 7th, 2012, 09:29 PM   #6 (permalink)
Rod Parsons's Avatar
My '91 American Standard Tele has 7 pieces with lam top and back. So does my '95 American Standard Strat. I think all of the earlier, ['87-2000???], had this confiruration.
I put a "paper in oil", .015 cap in my Telecaster. It sounds great, because the oil lubricates the electricity and makes it go faster.
Rod Parsons is offline   Reply With Quote
Old July 7th, 2012, 09:33 PM   #7 (permalink)
R. Stratenstein's Avatar
Amazing guitar! Exceptionally cool.
Old July 7th, 2012, 10:48 PM   #8 (permalink)
kwerk's Avatar
8 pieces in my challenge guitar this year.
Phil
Old July 7th, 2012, 11:46 PM   #9 (permalink)
crazydave911's Avatar
12 in mine from the build challenge last year . The limit is not gluing strength, it's weight. At some point the weight of the glue itself comes into play, but not with only 8 pieces
My Facebook
Old July 8th, 2012, 01:25 AM   #10 (permalink)
Nick JD's Avatar
My MDF guitar has ONE MILLION PIECES!
Sounds awful. Should have only used 999,000.
Old July 8th, 2012, 03:48 AM   #11 (permalink)
iocari's Avatar
thank you, i'll get glueing and clamping then, i really like the Harlequaster Crafty Fox, perhaps i may do a checkerboard caster from my smaller scraps
Old July 8th, 2012, 05:52 AM   #12 (permalink)
Crafty Fox's Avatar
I love the checkerboard idea. I did consider a tartan top (I'm originally from Glasgow, Scotland) but wanted to avoid gluing end-grains together. Just to be safe, I epoxy-glued the joined harlequin mash-up to a stiff maple veneer, running across the grain. The top is only 6mm thick and I wanted some reinforcement over the hollowed body. Looking forward to your build. Have fun!
