Walnut Telehawk build - Telecaster Guitar Forum
Old July 3rd, 2012, 01:26 PM   #1 (permalink)
trilby's Avatar
This is my second and latest guitar build. My first guitar was a Warmoth-parts Strat. Beyond a fat 1"-to-1" neck, a couple push-push pots for some series and out-of-phase combinations, and some killer Microcoils from Wilde Pickups, it's a fairly typical Strat.
The Body
After losing a bid on one of Brian Gipperich's semi-hollow Telehawk bodies on eBay, he sent me a curtusey e-mail letting me know that I could always contact him to have something built to my specs. I decided to inquire what tops he had, and in the return e-mail one of the Walnut blanks jumped out at me. Knowing that a Walnut/Mahogany combination would be well suited to oiling - really the only finish option I could accomodate in terms of both resources and time - I jumped on it.
It took me a while to decide exactly what I wanted the body to be. I decided that while I still wanted semi-hollow for the weight and resonance, I skipped the soundholes as I didn't want any of the beautiful Walnut removed. I also decided that I wanted something at least a little different from a standard Tele or dual-humbucker pickup configuration. In the end, I went with a "fat" tele setup; I knew I wanted it to have the Tele-style bridge pickup, but the neck route would allow for almost unlimited versatility if I wanted to switch things up later (humbucker, hum-sized P90, Tele neck pickup with a pickguard, blank pickguard for an Esquire, etc.).
The Neck
With the body on order, I hunted on Warmoth for a neck. Having been so pleased with the fat neck on the Strat, I once again made sure to narrow it down to the thick necks. I eventually settled on a beautiful looking all-Rosewood neck with some excellent coloring and striping. I went with stainless steel frets and a Graphtech nut.
The Pickups
Bill Lawrence's philosophy towards guitar pickup design lead me back to Wilde. I decided to try the L298-TL. I liked the description of it; some P90 beefiness, but still with some of that Tele twang. For the neck, I wanted something more P90-ish. I decided to go with the 3.6H version of the L610. This combination turned out to be similar to that another Wilde afficianado was using (L298TL & 2.4H 610), who found great success with the combination. Having heard clips of them in his Maple-necked Tele (Ash, Alder, I don't know), I'm curious to see how they'll respond in a Walnut/Mahogancy, Rosewood-necked semi-hollow.
In terms of wiring, the 3-way toggle switch will be used to provide a typical neck/neck+bridge/bridge setup along with master volume/tone. Having several push-pull pots lying around, I'll use at least one if not for both. I haven't fully decided what I'll do, but some present thoughts are:
1) switch between regular tone control and BL's Q-Filter (which I also grabbed)
2) Tone (and maybe Volume) bypass
3) "Half-out-of-phase" (OOP with a series capacitor)
4) Series/Parrel (though considering these are already pretty strong pickups, this might be fairly silly)
At the moment, I figuring it'll likely be #1, and maybe #2 as well if I'm feeling ambitious.
The Hardware
Armed with Bill's knowledge of the effect of Tele bridge material on bridge pickups (eddy currents, ferromagnetism), I decided to stick with a brass bridge from Warmoth to ensure the pickups stayed noise-free. As a hardtail guitar, I didn't feel it necessary to go insane on tuners and choose Warmoth's vintage style Gotohs. I chose an Electrosocket jack having heard good things about their quality. I went with a Gibson-style toggle switch and barrel-style amber knobs; we'll see what I think of that decision once it's altogether
Anyway...
As it currently stands, the neck and all the guts are on-hand, and the oil finish has been applied. I also have the tuning machines installed, and I'm just getting the string ferrules installed before I put the neck on and ensure proper bridge placement.
I haven't taken a picture of the finished body yet - or the neck, for that matter; all I have at the moment is a shot took a while ago of the mineral spirits-wiped body after it arrived.
Some reading for when you have nothing better to do: http://www.theuncomfortableproject.com
Music to make you feel better by comparison: http://soundcloud.com/theuncomfortableproject
trilby is offline   Reply With Quote
Old July 4th, 2012, 11:15 AM   #2 (permalink)
nblades's Avatar
Very cool, good luck!
I have a 1-piece Walnut tele body from Brian G at Tomahawk guitars, just waiting for me to finish amassing my parts and to get the courage up to build it into a guitar. Brian was very good to deal with, hope I can do justice to the body he sent me!
Happiness is not around the corner. Happiness IS the corner.
nblades is offline   Reply With Quote
Old July 5th, 2012, 09:23 AM   #3 (permalink)
Elias Graves's Avatar
That a slick looking top on there. Nice find.
Elias Graves is offline   Reply With Quote
Sponsored Links   #
Old July 5th, 2012, 09:26 AM   #4 (permalink)
javabirds's Avatar
Very, very, nice!
javabirds is offline   Reply With Quote
Old July 6th, 2012, 11:46 PM   #5 (permalink)
trilby's Avatar
Ugghh... hit an ugly snag. I went to fit the Warmoth neck onto the body this evening, only to find that the holes in the neck pocket are too close to the rear of the neck pocket, almost by 1/8" or so. I'm going to try taking the neck off my Tele thinline and see if it lines up, but I don't have a good feeling. I could take some wood off the rear of the neck pocket, but I'm a little nervous I won't be able to compensate for the shortening of the scale length with the bridge. Damn.
Old July 7th, 2012, 12:59 AM   #6 (permalink)
You could always just patch the holes in the neck and redrill them to match the body. It's a very simple procedure.
skipjackrc4 is offline   Reply With Quote
Old July 7th, 2012, 09:15 AM   #7 (permalink)
R. Stratenstein's Avatar
All other things being equal, this is a slam-dunk. Especially if only 2 holes are involved.
Old July 7th, 2012, 11:53 AM   #8 (permalink)
trilby's Avatar
Hmmm... it's a possibility. I don't like the idea of altering a perfect neck to match an imperfect body, especially when I don't know if other alignments on the body are already out of wack having found this one. I think I'll have to take some measurements first. Disappointing; I felt comfortable buying a body from Brian given the fact that no one had ever complained about this sort of thing with his work.
Old July 10th, 2012, 01:20 PM   #9 (permalink)
trilby's Avatar
Well, I finally had a chance to bust out my vernier calipers and take a look at the neck pocket last night. As I suspected, the neck holes - while perfectly spaced - are 1/8" too close to the bridge end of the pocket. The distances from the edge of the neck pocket to the bridge pickup cavity and string holes, however, are correct as per standard Tele dimensions, so it looks like the neck pocket holes are the only thing that are wrong.
So, that leaves me with a few options:
1) fill the holes in the Warmoth neck and re-drill to match the body. While likely the easiest option, I'm not going to go wrecking a perfectly compliant neck as then it becomes unusable with anything else if things go south.
2) take some wood out of the neck pocket so that the holes will line up. As it moves the entire neck closer to the bridge, it's a huge risk that I won't be able to compensate with the bridge placement and saddles, and it's much harder to get back from that modification.
3) fill the holes in the body. Whiles it's more difficult than re-drilling the neck, in the end, I end up with a neck pocket that will accept any compliant neck I see fit.
For the sake of doing things right, I'm going to knuckle down and do option #3. I still haven't decided how I'm going to get the new holes measured. I've seen some suggest putting nails in the neck holes and then pressing it to the body; I've seen others suggest using tracing paper. Given the 0.001" accuracy of my digital calipers, I may even just pencil it out in the pocket.
Old August 1st, 2012, 08:43 AM   #10 (permalink)
trilby's Avatar
Well, I finally re-drilled the body holes and the neck fits perfectly. Did a dry fit of the bridge with the bridge pickup installed and everything lined up beautifully. I couldn't have been happier.
But if that were the end of my trials, this would be too easy, right? Despite drilling the appropriate sized hole - and drilling/screwing into a test piece of wood so as to avoid surprises - I managed to break the head off the first bridge mounting screw. Trying to take this in stride, but I'm beginning to suspect I wasn't meant to build guitars.
On the plus side, I figure I'll love this guitar more than any other by the time I'm done, as it will impart the feeling of having battled a 50-foot tall mutant rhinoceros and am now riding it across the land in glorious victory.
Having failed to get it out using vice grips or drill chuck (neither method I'd probably recommend to anyone after having tried them), I'm going to go pick up an appropriately sized screw extractor if I can find one, as well as some metal tubing for the hollow-bit-drill-and-plug method as a last resort. Guess I need to pick up a new screw as well; I should have measured it before I left the house this morning. Darn.
Anyway, attached is a pic of my botched screw attempt, as well as a pic demonstrating that I've at least managed to do something right. Hopefully it won't be as long before I can show off some positive progress.
ID:	137230   Click image for larger version
Old August 1st, 2012, 08:53 AM   #11 (permalink)
oramac7891's Avatar
It's lookin good, good luck with the screw
oramac7891 is online now   Reply With Quote
Old August 1st, 2012, 09:12 AM   #12 (permalink)
nosmo's Avatar
It looks like the screw is sticking out enough to get it with Vise-Grips. What was the problem with that?
Whenever you do get it out, one tip you will see here quite a bit is putting wax on the threads when you install screws. Good luck with it.
Nice looking guitar by the way.
Telecaster - The AK-47 of the guitar world. Some may think its ugly...but it works!
nosmo is offline   Reply With Quote
Old August 1st, 2012, 09:14 AM   #13 (permalink)
Super Moderator
jkingma's Avatar
Thats a really nice looking piece of walnut.
Creator of Fine Sawdust and Expensive Kindling
Old August 1st, 2012, 09:19 AM   #14 (permalink)
ItZaLLGooD's Avatar
I really like that body style/ wood combo. Beautiful.
ItZaLLGooD is offline   Reply With Quote
Old August 1st, 2012, 09:34 AM   #15 (permalink)
trilby's Avatar
Vise-Grips didn't budge it; all I managed to do was grind the thread away. I had some wax on the threads, but perhaps not enough, or perhaps it just wouldn't have made a difference regardless. In any case, I'll get it sort out somehow.
Old August 1st, 2012, 10:16 AM   #16 (permalink)
nblades's Avatar
Chalk it up to learning experience, and continue-on!
Old August 1st, 2012, 10:24 AM   #17 (permalink)
GearHund's Avatar
A broken screw like that is a pain. I had it happen to me once and I could not get it out. So what I ended up doing is cutting it down flush with the body and cutting the head off of another screw with a hacksaw and super gluing it onto the bridge. So it looked just like the other screws once the bridge was in place. The other three screws still hold the bridge just fine. I have not had any trouble with it rattling or making extraneous noises somehow. It's the first bridge screw from the top in this picture.
I know it's not optimal, but there was no way I could think of to get that sucker out without making a bigger mess.
Name:	Nal - Front 2.jpg
GearHund is offline   Reply With Quote
Old August 1st, 2012, 12:19 PM   #18 (permalink)
trilby's Avatar
The thought had crossed my mind of just grounding it flat and just relying on the other three screws; as you say, they'll hold the bridge just fine. I'm not sure I'd even care about the aesthetics of gluing the head to the bridge, as once the saddles are on you're barely going to notice any way (and I don't give a darn about affecting it's 'value', as after the work I'm putting into this guitar it's not going anywhere... ever). Hmm, food for thought...
By the way, awesome Tele Jr. you have there.
Old August 1st, 2012, 09:16 PM   #19 (permalink)
Try heating it up with a soldering iron and having another go with Vice-Grips with new sharp jaws tightened painfully tight. Put a small hole in the center of a couple of shirt cardboards and use them to shield your guitar top. Also slight taps around the sides of the stub may loosen it. EZ Out (screw extractor) is a waste of time in this circumstance and with a little more work you can avoid the use of a plug cutter.
Old August 2nd, 2012, 02:14 AM   #20 (permalink)
Bentley's Avatar
I say putting the screw in a stationary vice and REALLY clamping it, then turning the body. It might sound risky, but I think that's the best bet.
Bentley is offline   Reply With Quote
» Random Photo for Guests
Dugdales Lounge late 1980's
» Recent ThreadsGuests
Fender Logan Custom Guitars
