#41 (permalink) |
Parrallelogram jointers are the way to go in my opinion. They are much easier to work with compared to those old rail/wedge and dovetail setups.
the now mandatory =====> |
#42 (permalink) |
* warning - cell phone pictures
Did a little cutting after the body laminations had ample time to dry. I cut close to the line on the bandsaw ![]() ![]() Oh yeah, that glued up nicely ![]() Then I sand close to the line removing any jagged areas that could cause tearout issues. Convex curves with the belt ![]() Concave curves with spindles ![]() I hit it with a sander quickly so you could see how well the join line came out.
#45 (permalink) |
A lot of folks ask me what I use to attach my templates, and I reply, Duck Brand double sided duct tape.
![]() After the template is attached, I use a 2" spiral bit to route the perimeter. One swipe, and I am done. Love these bits. ![]() Let's take another look at the laminated joint ![]() Cavities are then hawged out with a forstner bit
#46 (permalink) |
Then I take a ruler and mark my key depths along the edge of the body. 11/16" for the neck pocket and neck pickup cavity. ( I believe the drawing says 5/8"). 7/8" for the bridge cavity, and I route the control cavity 1/4" from the bottom. On a 1 3/4" body, I route a full 1 1/2" deep cavity, but I like making these blackguards 1 5/8" or 1 9/16" thick.
![]() While the depth is set to 11/16", I route all three cavities. ![]() Then I change the depth to 7/8" and route the bridge pickup and the control cavity. I can not route the control cavity to full depth with the template on, so that has to come off. However, before I remove the template, I drill the two outer string through holes about 1/4" deep. ![]() Then I remove the template and route the control cavity to full depth.
#47 (permalink) |
Afterwards, I affix my Neck Pocket template.
![]() Hawg the pocket out with a forstner bit, and route it out. ![]() Then I clean up the pocket using a sharp pocket knife and a piece of sand paper. ![]() ![]() Then I added some edge round over using a 3/16" bit. Generally, its a good idea to sand the edges before this step, but I got ahead of myself. Worse case, I may have to run the roundover bit over the edge again. I doubt it will come to that, but even if it did, it only takes 15 seconds to run the router around the perimeter. ![]() All the way around on the top, but on the back, I stop shy of the neck pocket area
#48 (permalink) | |
But I do have another question: where did you get your 2" spiral bit? I'd really like to try one of those on my next build. The straight flute bits just make tear outs too easy. Thanks!
------------------- "There ain't no such thing as a free lunch." -- Robert Heinlein |
#49 (permalink) |
Here is a super cool jig made from the dimensions on Terry Downs Tele Pdf
![]() ![]() ![]() It is 1" steel with the string through holes and bridge mounting holes drilled all the way through. I simple index the jig with (2) 1/8" drill bits, and drill the remaining holes. As I drill the middle holes, I can move the outside bits to the center to keep everything lined up and make room for the drill for the new holes. Then I drill the pilot holes for the bridge. I only drill the string through holes about 3/8" deep. They don't need to go all the way through at this point.
#50 (permalink) | |
Eagle America MLCS Woodworking I am pretty sure they are the same company because when I ordered router bits from them, they were shipped from the exact same address. Outstanding job on that sparkle guitar. Looks brilliant. One question, is it equipped with Left handed tuners?
#51 (permalink) | |
#52 (permalink) | |
http://www.amazon.com/RFT5200-CARBID...8047898&sr=1-1 This is the one I have. Awesome bit, but expensive. Saves a ton of time on the router table. Also works great as a jointer if you don't have one. |
#53 (permalink) | |
Have a good one! And thanks again for all the great knowledge.
#54 (permalink) | |
#55 (permalink) |
Super Moderator
Very nice.
Thanks for sharing. Do you ever study? Or are you finished with your program?
"If you can't say something nice... don't say nothing at all." - Thumper the Rabbit "She's not only merely dead, she's really most sincerely dead." - The Munchkin Coroner |
#57 (permalink) |
I graduated with a Masters of Science a few weeks ago. Cummulative 4.0 gpa. Now I am looking for a PhD program. I have a prospects that I intend to visit over the summer.
#59 (permalink) |
great thread colt. congratulations on getting your Masters.
http://www.youtube.com/user/telemast...e=results_main 1911 Grips---> http://www.youtube.com/user/Lonestar...s?feature=mhee |
