#21 (permalink) |
Nice saw jerk! Haha jk thanks for posting this stuff! You sweet builders are like the luthier school I never had and its really helping out my novice butt!
I need to build a planer bozx |
#23 (permalink) |
Yep...great thread Colt!!!
Please like my Facebook page at...http://www.facebook.com/DeltaGuitarWorks Visit my music and songwriting page at...https://www.facebook.com/TheWildwoodSessions |
#24 (permalink) | |
I think I will go fishing tonight.
the now mandatory =====> |
#25 (permalink) |
Went down to the shop this morning, and had to get past the guard donkeys.
![]() Ripped the glued up boards on the TS so they would fit in the planer ![]() I cleaned off excess glue with a sharp chisel. Sharp being the key word.
#27 (permalink) |
Trimmed the perimeter with the bandsaw
![]() ![]() Layed out the area for the chambering. This Ash was cut in Kentucky, not a swamp in Southern Louisiana, so its not super light ![]() Chamber the body leaving ¼” of material on the bottom. I route using several shallow passes.
#28 (permalink) | |
I am headed to a local farm today to show big city girl our local donkey who is the real lonely donkey before the Shrek series. |
#29 (permalink) |
PPE
![]() Nice and light now. ![]() This is how I glue laminate joints. ![]() I put some streamers of glue, then even them out with a paint roller. It is important not to slather the glue on in laminate joints. Just a nice even thin layer. Too much and the pieces will slide everywhere when clamping, and the squeeze out will be an extreme mess. Then some clamps. Checking for even squeeze out, all the way around. If you look close, I don’t have excessive squeeze out.
#30 (permalink) | |
No slip then.
#31 (permalink) | |
But the screw trick does work well. I do that or use line up pins when im glueing some of my furniture projects where I'm glueing finish shaped pieces together.
#32 (permalink) |
Great thread!
I use hard ash for most of my builds. Availability. Swamp ash obviously quite expensive here in Europe. That's why I designed my main model as a thin line. full ash body just too heavy. Once did a full body tele though: sustain=huge, compensates for the back aches :) |
#35 (permalink) | |
The blades and tables came setup Dead Nuts accurate. After it was assembled, I simply squared up the fence with my machinist square, and set the height of the infeed table by running a board across the knives a few times. I was so impressed with that machine, that I intend on buying a big Grizzly Bandsaw, drum sander, table saw, and spiral cutterhead planer as money allows. Mine is equipped with 4 straight knives
#37 (permalink) |
Glad to hear about the happiness with the jointer. I need to buy a bandsaw first but will probably buy that same jointer with the spiral cutterhead afterwards. Do you like the parrallelogram adjustment?
#40 (permalink) |
Awesome stuff Colt - if your Masters isn't in Education, it should be. Your an excellent teacher - thanks for doing this.
Way too many tools, and not enough wall space for my guitars . . . . . |
