Can you put a strat neck on a tele body?
I just read that the SRV and Eric Johnson strat models have 12" radius necks. Just what I want for my Tele (flat fingerboard for easier bending, instead of a radius neck where the strings fret out). Is it possible to put a strat neck on a tele without having to reshape or mod it, or are they two different neck shapes where they join the body?
Of course you can, there will be two small pockets where the neck meets the body.
I just got lucky with my cheap project, the Strat neck seemed to be 1/16ths longer than the scale of 25.5 so I ground a 1/16th off the neck, the pockets are now gone. Initial measurements say it will be good. I'm a long way off from finding out for sure. Do a google powered search as well. |
strat neck will bolt on a tele body with no mod's
tele neck will not bolt on a strat body without cutting
four on the floor, and a fifth in my hand gonna ROCK&ROLL ya to the promised land |
#8 (permalink) | |
![]() It took a little modification, but the Tele-style neck fit my Partscaster just fine. The 22nd fret overhang hides a lot of sins.
my guitar photo album |
#9 (permalink) | |
Clapton had a Tele Deluxe (I think) with a Strat neck when he played Hyde Park, London with Blind Faith a loooooong time ago. I think the neck came from 'Brownie'? I think it looks OK, but I've never felt the need to swap them over on my Strat & Tele.
#12 (permalink) | |
I was in England at the time. (June 1969) |
I was lucky with this
![]() That's another partsbincaster. Converted Bullet strat neck on a tele body. It came out pretty well. I've checked the scale lenght (654 mm from nut to center of mounting screws) and found out that neck has 3.5 mm extra lenght. So i just removed it from the rounded maple part of the heel, not touching the fretboard itself. It overhangs the body, so i could even left stock scratchplate. I sure had to fill the old holes in the heel and redrill. Intonation is fine, fit is... i would say ... perfectly tight) Last edited by parkwood; May 17th, 2012 at 09:43 PM. |
#14 (permalink) | |
or round the heel?
round the heel
I traced the outline on the end of the neck and sanded/filed a channel where the neck contacts the body. There was enough room on the bridge that it intonated correctly. The 22nd fretboard overhang plus a tight fit on the pickguard makes it invisible.
