0.2in/5mm neck difference
Hi folks,
I've recently come into possession of a 2in wide piece of billet aluminum. After seeing the aluminum tele built for the TDPRI build challenge and always fancying Travis Bean's, I was wondering if building an aluminum neck was a possibility for a summer project. the piece is 2" (50.8mm) wide, which is a bit narrow for a standard 6 string neck. I've seen most standard 6-string guitars are about 2.25" (57mm) at their widest point, so I'm wondering if .2in/5mm would be that significant to render the project moot. |
Make a guitar with a narrower neck. They used to make tenor necks on guitars for 4 strings. Make a 5 string neck?
The bridge would have to be custom made and obviously the string spacing will feel a bit different.
Institute of Incomplete Guitar Projects |
If you make the neck only 2" wide, the bridge will have to be custom made so that the strings don't fan out as far. This really might make a great slide guitar type neck, though, if you could get around making a bridge for it. Better for chords than for fingering individual notes.
My main concern is the high and low E strings sliding off the board. As far as nut and bridge, I plan on cutting a nut and as for the bridge I'm things of a fender style bridge a la strat or tele. I'd really like a six string but have been looking at the Warren Ellis tenor and Keith Richards 5 string, I just don't know much about tunings outside of six and twelve.
Somebody did make an aluminum neck for the 2011 build challenge. That series of threads isn't up right now, but it should be in a few weeks. As I recall his only complaint was how neck-heavy the guitar was.
Nothing ruins a Friday faster than remembering it's only Tuesday. |
