#21 (permalink) |
That's a pretty interesting strat body. Ive never worked with bronze. How hard is it to manipulate?
#22 (permalink) |
alu
Yes, aluminium is great
the best tool for cuting aluminium with max precision ![]() Uploaded with ImageShack.us some non finished work ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us |
#24 (permalink) |
string ferrules
This photo session was made quick. Some of this is dangerous, so use extra tools - do not hold it in your hand
finish screw box - 5 mm on a 5mm screw without head rasp easy ![]() Uploaded with ImageShack.us if you want to use sand paper you can but only small piece - it is a dangerous if you use long piece of sand paper - rotor can cath the end and cut you badly ![]() Uploaded with ImageShack.us Use a triangle rasp so ferruel better cacth the wood ![]() Uploaded with ImageShack.us mark it for drilling ![]() Uploaded with ImageShack.us 2 mm is more than enough - do not use your fingers while drilling ![]() Uploaded with ImageShack.us finished from outside ![]() Uploaded with ImageShack.us inside ![]() Uploaded with ImageShack.us drill carefully use a piece of wood to stuck in hole ![]() Uploaded with ImageShack.us I think I forgot something - drill with 5 mm driller very slowly to remove inside screws ![]() Uploaded with ImageShack.us maybe it looks funny but it works for me. I use 010 strings and no ferruels moving in cheers |
#26 (permalink) |
some string tree
I have a smaller string space, so have to make own string trees. Don't laugh at me, it can be done very easy and fast with small rasps. I didn't polish them
![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us to be continued... |
#27 (permalink) | |
#28 (permalink) |
Using set screws for ferrules is a neat idea, but yeah, I could see many a broken/dull drill bit from that exercise... should look around and see if anyone makes them in brass.
#30 (permalink) |
Funny how everything I think of someone on here is doing already. I'm currently finishing a couple of stainless steel bridges. I chose to use only hand tools to prove a point to myself. I have access to a lathe and milling machine and will probably do a few in a more professional way.
#33 (permalink) |
very cool. i have some wrought iron that is a few hundred years old i plan on using in a build down the road after i get some experience ( i used it in building knifes.. looks great when etched). def will make a tone bar out of it. hard tail would be cool i like the design above. i wonder if my forge will fire up. not used in quite a while. ill burn that iron when the time comes.
chris. |
#35 (permalink) |
formerly "Big" Mike Simpson
I like making some of the parts when I can... just because I like making stuff.
I made the neck plate, bridge, control plate and knobs out of copper for my 2009 challenge build. I made the pickguard out of leather. I made the neck plate, bridge and control plate out of copper for my 2010 challenge build. I made this pickguard out of garolite (bakelite) I made this guitar in June 2010. The control plate and neck plate are made out of stainless. I made the pickguiard is b/w/b material. On all of these guitars I made a ferrule block. The 2009 guitar was copper and the others I made from brass. This one is in my 2012 challenge build. http://www.tdpri.com/forum/2012-tdpr...ml#post4101192 |
#38 (permalink) |
I finished this "tool" today, it's for making my homemade hardware. Guess what it is
![]() Put a piece of sheet metal in the gap, place it in a hydraulic press and press.. And voila! ![]() After some grinding You got your self raw tele bridge..
