Old April 14th, 2012, 05:56 PM   #1 (permalink)
High-Figure Walnut Pickguard - Finishes?
Hey All,
I have a finishing question for you. I have 3 pickguards made from high-figure walnut burl - pic below.
My question: what to finish it with? I'd like a nice, built-up gloss finish. My concerns are crazing or cracking due to flexing (it's pretty thin) and I also need to pore-fill quite a bit. Epoxy? I can spray Nitro - I've heard the Behlen's instrument lacquer is made for more flex than the regular nitro lacquer. Any input greatly appreciated!
AlanT is offline   Reply With Quote
Old April 15th, 2012, 03:48 AM   #2 (permalink)
dr_zaius's Avatar
I use watco danish oil on my wooden pickguards. I figure clearing over them would just look awful after the pick does its damage after a week of normal playing. The danish oil doesnt give it a gloss, but it does bring out the beauty in the wood, and the pick attacks don't seem to bother it much. Also watco can be re-applied at any time with minimal prep.
dr_zaius is offline   Reply With Quote
Old April 15th, 2012, 08:55 AM   #3 (permalink)
Fabulon floor finish!....Nice and hard AND scuff resistant!
ehawley is offline   Reply With Quote
Old April 15th, 2012, 10:12 AM   #4 (permalink)
emoney's Avatar
I think I'd use a poly based clear, finishing it separately from the body of course. It's going to be very nice however you do it.
emoney is offline   Reply With Quote
Old April 16th, 2012, 12:48 PM   #5 (permalink)
Thanks for the responses! Maybe I'll try one of each. I'm particularly interested in making sure the finish doesn't crack. With such a thin piece of wood, it could easily crack/craze with the pressure of mounting it. The Watco definitely would not crack and I can see that a floor finish would be formulated to allow some flex.
Old April 16th, 2012, 02:01 PM   #6 (permalink)
dr_zaius's Avatar
Here's an oak Strat pick guard finished with Watco Danish Oil (natural) and for comparison, a pic of the unfinished oak the guard was cut from.
Old April 16th, 2012, 08:15 PM   #7 (permalink)
tnt423's Avatar
You could always use decoupage clear and build it up thick. It's been done before and can be buffed if scratched, just make sure that the last coat is levevel enough to sand and buff so you don't get witness lines.
Very nice burl there.
Thos.
"Make your own mistakes not someone elses, this is a good way to be original !"
tnt423 is offline   Reply With Quote
Old April 16th, 2012, 09:17 PM   #8 (permalink)
Colt W. Knight's Avatar
I would seal that with Birchwood Casey Sealer/ Filler, then apply clear lacquer. Wet sand with 1500 grit, then buff with a light duty polishing compound and apply a wax. It will look like a million bucks.
the now mandatory =====>
Old April 17th, 2012, 02:53 AM   #9 (permalink)
tiskit86's Avatar
Yep. /\ /\
But I like walnut best when it's darker and 3 dimensional, so I might also use a little stain too to get it darker brown. It might be dark enough after the BC filler/sealer though.
tiskit86 is offline   Reply With Quote
Old April 17th, 2012, 04:07 AM   #10 (permalink)
dazzaman's Avatar
I am days away from starting to apply a finish to a burr walnut pickguard in my challenge build. My finish will be nitrocellulose. In my case the guitar is for me, and I pick with my fingers so there is no risk of damage. If you have the time to wait you could always see what happens in my case - even if it is a lesson in what NOT to do...
dazzaman is offline   Reply With Quote
Old April 17th, 2012, 01:09 PM   #11 (permalink)
SixShooter's Avatar
Shellac is a very traditional finish for walnut furniture. Amber shellac would warm it up quite a bit. Another idea would be Tru Oil. Do some tests on scrap.
"Something entirely new in the electric Spanish guitar field..."
SixShooter is online now   Reply With Quote
Old April 17th, 2012, 01:12 PM   #12 (permalink)
Originally Posted by tiskit86 View Post
Yep. /\ /\
I really like the color of air dried black walnut with a clear finish, but kiln dried walnut looses some color. It almost has some grayish tones. I will stain those.
Old April 17th, 2012, 01:14 PM   #13 (permalink)
Here is an example of amber shellac.
