Old April 8th, 2012, 11:07 AM   #1 (permalink)
Pretty's Avatar
Humbucker in neck
I have a Tele that sounds very...Tele-like. Typical 2 pickup single coil setup, but essentially, if I wanted to, could I put a humbucker in the neck position? Because I almost want some badder, humbuckier sounds, but I wanted to know if I could have 1 humbucker and keep my other single coil. What suggestions does everybody have? I want to hear more on this subject.
Pretty is offline   Reply With Quote
Old April 8th, 2012, 11:44 AM   #2 (permalink)
You can get another pickguard and re-wire it with the humbucker and be fine, but the middle position won't sound normal. I'd recommend using a 4-way switch with the pickups you have now, with the 4th position being the pickups in series. I did that a few months ago and it gets really close to a humbucker sound while keeping the single coil options.
Nothing ruins a Friday faster than remembering it's only Tuesday.
PHawley is offline   Reply With Quote
Old April 8th, 2012, 11:45 AM   #3 (permalink)
alscort93's Avatar
Fender and Squier does it all the time. If all you'll use the humbucker for is neck position work, you'll be fine.
alscort93 is offline   Reply With Quote
Old April 8th, 2012, 01:02 PM   #4 (permalink)
Crazy John's Avatar
If you will be using a PAF-sized humbucker you will have to rout the body and you could also wire it like a "Fat Tele" with a 5-way switch. See Fender's website for wiring diagrams - and the 5-way switch is NOT your typical Strat switch - good luck.
Crazy John is offline   Reply With Quote
Old April 9th, 2012, 11:44 AM   #5 (permalink)
Mebbe you bought the wrong Tele?
Tuxedo Poly is offline   Reply With Quote
Old April 10th, 2012, 06:34 AM   #6 (permalink)
Crafty Fox's Avatar
I agree with PHawley on using a 4-way switch. I've got one on my Vintage RI and I love it, and no irreversible damage done to the body. So it can easily be converted back to original. I seem to recall having to cut the ground wire from the neck p'up cover. However, I've just completed my new build "The Harlequaster" (see other thread) and I used a Gibson mini-humbucker on that. I was expecting to use the new Fender Super 55 at the bridge but the one I was sent doesn't work so I put in a Fender Hot Alnico for the time being. I'm actually very pleased with the sounds, in fact the 2 p'ups together have a slight out-of-phase tone to them which was quite unintentional but I like it. I've got 500K pots in the Harlequaster.
Crafty Fox is offline   Reply With Quote
