Old April 2nd, 2012, 01:46 PM   #1 (permalink)
string through holes
Is there a difference to where the holes go on a hardtail bridge and a regular tele bridge?
stng72 is offline   Reply With Quote
Old April 2nd, 2012, 06:35 PM   #2 (permalink)
dsutton24's Avatar
There's not an easy answer to this question. When you say 'hardtail bridge' do you mean a Strat hardtail bridge? If so, which one? And by 'regular Tele bridge' are you talking about an American, Mexican, Squier or Afinity?
Yet another hobby that is completely out of control...
dsutton24 is offline   Reply With Quote
Old April 3rd, 2012, 08:45 AM   #3 (permalink)
hardtail-short bridge with 6 saddles
regular tele- american traditional bridge
Old April 3rd, 2012, 06:25 PM   #4 (permalink)
Novatuc's Avatar
There is probably a difference in the position of the holes. Not sure about the bridges you mention but for Gotoh stuff there is about a 1/8" difference between the hardtail and the modern Tele. Also the string spacing is different, 2 1/8" versus 2 1/16". Hope that helps a bit.
Novatuc is offline   Reply With Quote
Old April 4th, 2012, 10:23 AM   #5 (permalink)
Jack Wells's Avatar
If by "American traditional bridge" you mean a vintage style bridge, consider all vintage bridges the same. It doesn't matter where or by whom they're made.
..........for Gotoh stuff there is about a 1/8" difference between the hardtail and the modern Tele.
How did you come up with this 1/8" difference? Seems to me you would just put the bridge holes over the body holes and mount the bridge. Also, 1/16 in. difference in string spacing is not worth consideration.
Old April 5th, 2012, 09:52 AM   #6 (permalink)
Crafty Fox's Avatar
There can be differences in hole positions, eg, I've got an early Vintage RI which came with a type of Am Standard bridge as an extra. This Am Std fits perfectly but I bought a new Am Std bridge for my current build and found that the string-thru holes are in a different postion to the others. It's also thinner and lighter in weight than the older Am Std. All 3 are US made and so I expect there will be further differences in components made in other countries. Make sure you clarify the positions if you are using a StewMac template as it is drilled for Vintage.
Crafty Fox is offline   Reply With Quote
