Advice needed - truss rod rout
For my challenge doing a 3/4 size tele. I'm making a single action truss rod so I need to make a curved rout.
I have a full size neck plan that shows the curve but what do I do for 3/4 size. The neck is normal thickness but length is shorter (obviously). It isn't exactly 3/4 cause apparently 3/4 isn't 3/4 (no idea) Anyway full plans show that the rout is 1/2 inch deep in middle. If I do this on a shorter neck then the curve is much greater. Don't know if that is a prob. Any help is appreciated as its going to hold me up soon. Cheers |
I'd probably keep the angles the same at both ends as well as the depth in the middle. Just redraw the curve through those 3 points. You could flex a thin piece of wood and use that as a guide for a pencil or use CAD.
Institute of Incomplete Guitar Projects |
Just make sure of your cut as it applies to the back of the neck. If the neck is going to be proportionally thinner a standard depth might now leave enuff wood on the back.
Just another squirrel trying to get a nut |
Thanks guitar builder.
Im thinking of measuring the length of the 3/4 plan vs normal plan. Work out what % ren is and apply that to the depth of the middle section. The full plan shows depth of middle as 1/2inch. If the pln measures 80% shorter then I'll go .4 inch deep. I'll mark on mdf the two ends and the middle point. Then I'll bend the rod nil it hits 3 points and tn trace it. That will be tomorrows effort. Cheer |
Maybe you can just add a steel reinforcement instead of actually doing a real adj. rod? I had an import kids 3/4 neck here that has no visable adjustment rod in it.
What is the scale length of you small sized guitar? Forget all the 3/4 stuff. The literature calls all small size guitars 3/4 size. It's meaningless. The curve of the truss rod on a Fender is made up of two different radii. See this drawing.
![]() Divide your scale length by 25.5. Multiply this by the radii shown in the drawing to determine the curve for the truss rod channel in your neck. As an example I started building a small Telecaster with a 22.75 in scale length (same as the Squier Mini-Strat). 22.75/25.5 = 0.89 0.89 x 255 = 227 in. 0.89 x 115 = 102 in. These are the radii of the curve for a 22.75 scale length. However I doubt that the curve needs to be exact. Anything close should work.
. Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" I'm just not cool enough to be a Mac person. I'm a PC and Windows 7 was my idea. |
Are you doing a one piece neck or gluing on a separate fretboard? You may want to consider a hot rod type rod or you can make a ric style rod in any length. Those have a metal adjustment block and are only one way rods. They are easy enough to make and fit into a flat slot. Those are obviously easier options than making a special jig for a one-off neck.
Thanks jack.
My scale length is 22.625. It rounds up to 89% which puts same dimensions to yours. I'll give the jig a shot tonight. Did you leave the neck the std thickness or did you bring it down. Guitar builder. I am using a fretboard. I thought about the stew Mac hot rod but went the harder route as I wanted to try making my own truss rod. The steel rod is a good idea but again I'm using the challenge to build up some skills for my next build. (it seems addictive) Thanks for the help guys I really appreciate it. Cheers |
