Relicing a body - getting the nitro to crack/craze
Hello all.
I've finished a Tele body using nitro and after 11 months of the body sitting in the sunshine (well, occasional sunshine, this is the UK!) I wanted to get the finish to crack as it's a relic project. I've used a -50 freeze spray on the finish but am getting no change at all. The finish is solid and I used plenty of coats of clear (before sanding back of course). Any ideas why I'm getting no effect? Too thin? Many thanks!
www.bigtimecharlie.info |
The freeze spray worked really well on mine. Is the guitar body already cold when you hit it with the freeze spray? I stuck mine in the sun for an hour or so and then hit it with freeze spray and I got little crazing type cracks all over.
I also stuck it in our extra freezer for about 2 weeks (I sorta forgot about it, I had a lot going on). When I took it out it had nice cracks all over the finish. In the pictures the bigger cracks are the ones that happened from being in the freezer and the little tiny cracks (if they show up in the pic) are from the freeze spray. ![]() ![]() ![]() ![]() It also helps the cracks to show up if you rub something dark into them right away. I found the nitro sorta healed itself a bit so having something smeared into the fresh cracks helped. |
#3 (permalink) | |
@Muzikp - Where did you get the single-ply humbucker pickguard? Is it Bakelite/Garolite? |
SFC - If you need a bakelite guard with a hummer route, send me a PM. I am making a batch of guards this weekend, and I am sending one to another member. I can send you one too.
the now mandatory =====> |
#6 (permalink) | |
Good man, Colt.
Phil I'm full of dust and guitars - Syd Barrett |
#7 (permalink) | |
#8 (permalink) | |
Too much plastics in modern nitro lacquers? I’m by no means an expert on paint or relicing, but I’ve read this: http://www.ruokangas.com/?p=7067 |
Freeze Spray is the only thing that worked for me. I've tried going from a hot spot to the freezer overnight - nuthin, went from 5 degrees F to holding it in front of the furnace register - nuthin. I use auto air conditioner charge and actually pour the liquid onto the body. I then rub shoe polish and liquid dye into the cracks before they close back up.
You're gonna need a bigger boat! |
#10 (permalink) | |
Liquid Nitrogen "LN2" which can be had from welding suppliers boils at 77K = -196°C
It is very, very, very cold! and requires careful handling but is not what we would call dangerous.
#12 (permalink) | |
But it sounds a lot easier to just give Colt your address |
#15 (permalink) | |
I already found the right Garolite to order from McM-C (for future reference) in a thread I started the other day. I just like to track down all the sources I can as I go along; I found a $20 savings on my chosen bridge that way last week. |
#17 (permalink) |
I'm sure there are chemical differences in lacquer make up over the decades and yes, lacquers made for stringed instruments do have plasticizers in them because not everyone wants their one year old guitar to look like shi...er, um..I mean, cool and old. However, Mr. Ruokangas is leaving out that these ultra-thin old vintage lacquer finishes have been curing...and losing plasticizers....for 40, 50, 60 or more years. The reason they are so hard and so thin is because they are old, worn and have sunk tremendously from when they were new. BTW, I have a 79 yr old wood body National that's lacquer finish gets sticky under my arm just like he claims only modern lacquers do. |
#18 (permalink) |
Thanks all for your input. I tried yesterday to do the hairdryer/freeze spray combination and on close inspection I DID get some checking. However I think it is only happening in places where the finish is thickest. I will try it again and this time rub something into the cracks because as someone has said, the lacquer seems to have 'healed' over and so I can't see anything now.
#20 (permalink) | |
I've had old guitars before that get gummy, while others of the same make, model and year do not. Sometimes I think it depends on the chemical composition of the skin oils of whomever owned it the longest. |
