Old February 2nd, 2012, 01:38 PM   #1 (permalink)
Olav's Avatar
??Lefty Stacked Concentric Pots??
Peeps, I'm redoing the wiring in my Hagström Select Ultra Swede. It has 1 Volume and 1 Tone pot. Also featured are coilsplitting and the obvious pup selector for bridge and neck. What I'd like is the switching flexibilty an LP has but on two knobs (this making sense?).I'm planning on replacing the V and T pots with concentric pots to give me that. Being a lefty I'd highly prefer reverse tapered pots. Anybody know where to get those? Thanks.
va' sa' du? va' hete' du?
check my guitars@LGTf
Olav is offline   Reply With Quote
Old February 2nd, 2012, 01:54 PM   #2 (permalink)
jkingma's Avatar
If you were 25 years older you would have been forced to be right handed as a kid and you wouldn't have these problems.
Old February 2nd, 2012, 02:01 PM   #3 (permalink)
Olav's Avatar
I'd probably not be playing the guitar if I were forced to be a 'right'y. That's a discussion I'm not willing to enter anymore though. I know it's a long shot, but I thought if I were to ask anywhere... here would be a good place to do it.
Old February 2nd, 2012, 02:10 PM   #4 (permalink)
jkingma's Avatar
Danelectro made a lot of lefty guitars and most of theirs had concentric pots... but knowing Dano, they probably used righty pots.
If I find any source, I'll let you know.
Old February 2nd, 2012, 02:24 PM   #5 (permalink)
crazydave911's Avatar
Ok, I'll bite finally. I've just took apart three pots out of my junkbox (three different brands too). I don't see one blessed thing that makes them "righty" or "lefty". Shouldn't wiring a pot opposite of standard convention, by default make them a "lefty"? Help me understand this
My Facebook
Old February 2nd, 2012, 02:56 PM   #6 (permalink)
The taper of an audio pot would determine righty-ness or lefty-ness. Reverse audio would be what a lefty wants. For linear pots (not generally used on guitars) it would be a non-issue.
mlp-mx6 is offline   Reply With Quote
Old February 2nd, 2012, 04:03 PM   #7 (permalink)
Olav's Avatar
John, thanks, if you do find anything please do let me know.
Dave, I blow at explaining this but you can trust me on this. Reverse soldering a regular pot isn't gonna do the trick. 100% volume for 75% (or more with some) of the way and a sudden steep drop for the last 25%.
MLP; All concentric knobs I found are audios though (which isn't a surprise of course), so that's what makes this hard.
Thanks fellas.
Old February 2nd, 2012, 04:43 PM   #8 (permalink)
jefrs's Avatar
No problem with linear pots stacked or otherwise, ok for lefty or righty.
Reverse-log pots are log/audio pots that work backwards, would work for lefty as an audio-log pot (if wired backwards). I have never seen a stacked one.
You can convert a linear pot to pseudo-log by fitting a fixed resistor of R=0.83Vr between wiper and ground (you have to double the value of the pot too - a 500k Vr + 420k R makes 220k) if you switch which end is ground you get a left-handed (reverse-log) one. This does work for potentiometers but I need to think about how to rig the rheostat variable resistor for the tone control ...
So "10" is full Vr resistance in series with the cap, ok. So if the hot connection is at the "0" end and the cap is on the wiper then the fixed goes between wiper and "10". I have not tested this one.
Old February 2nd, 2012, 04:46 PM   #9 (permalink)
otterhound's Avatar
I've never found any . Doesn't mean that they don't exist somewhere . Possibly could be sourced in Japan if they exist anywhere .
otterhound is offline   Reply With Quote
Old February 2nd, 2012, 05:10 PM   #10 (permalink)
Olav's Avatar
Let me get this straight. I'm planning on rewiring a humbucker guitar, I'll typically want 500k pots for that. So, I start out with 1Meg pots, than place a resistor between wiper and ground. What value resistor do I need for this? Can't wrap my tiny brain round the reverse logic... Now I know how Dave felt. Not saying you got as tiny a brain as mine Dave...
Old February 2nd, 2012, 08:00 PM   #11 (permalink)
jkingma's Avatar
Originally Posted by Olav View Post
...Not saying you got as tiny a brain as mine Dave...
Sounds like ya are...
Old February 2nd, 2012, 08:22 PM   #12 (permalink)
Too danged funny
My Facebook
Old February 3rd, 2012, 03:25 AM   #13 (permalink)
Olav's Avatar
That Kingma feller is in a strange mood... Must be the sudden rush of wooddust.
I have a couple leads to read up on that tell how to trick out a linear pot to do what Jefrs suggested.
But today the snow came to my part of the world, so I'm working...
Old February 3rd, 2012, 11:06 AM   #14 (permalink)
jkingma's Avatar
Ain't the wood dust... it's all the other $hi!t life keeps dumping on me...
Old February 4th, 2012, 08:19 PM   #15 (permalink)
jefrs's Avatar
Like what I said R = 0.83 x Vr
0.83 x 1Meg = 830k
Nearest preferred value R is 820k.
Put this across wiper to ground and you get 450k which will be near enough 500k
This will be a pseudo-logarithmic pot for most of its travel. Do note that audio pots consist of 3 or 4 linear tracks laid end to end, to describe their operation as logarithmic requires a poetic license.
However as you reduce the volume to zero, the load on the pickup will increase to 1Meg, which may make the output a little brighter.
I'm either-handed. I find it very confusing when confronted with pots wired backwards. I always expect clockwise to increase volume.
Me. I'd fit a linear vol pot anyway - 500k linear for a full humbucker.
Old February 4th, 2012, 08:24 PM   #16 (permalink)
jefrs's Avatar
You are not looking very hard
http://www.cricklewoodelectronics.co...me.php?cat=489
Also Farnell, RS etc etc
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
