#121 (permalink) | |||
BTW, sorry Herb for the hijacking
"No trees were harmed in the creation of this message, however some electrons were temporarily inconvenienced." My Facebook |
#122 (permalink) |
Iain , that is a fantastic idea , I for one would love to see something like that in the build challenge.
Herb I don't always play guitars , but when I do , I prefer tele's , stay twangy my friends |
#123 (permalink) |
Hijacking , what hijacking ? Nothing of the sort Dave , lots of good info and ideas coming out in this thread IMO , and a few laughs too , I spit my coffee when I saw that cat picture !
#124 (permalink) |
Got the fret dots on her , I was going to paint them on like the original , but all my test pieces were sloppy , a little bleeding on the edges , I was not happy with the results , so what I did was this.
I printed out the finger board from Mister B's pdf on peel and stick paper , cut it out and lined it up on my necks fret board and stuck it on . ![]() Then I took a 1/8" brad point bit in the drill press and marked it with tape for depth at about 1/8" depth and drilled the fret markers through the peel and stick paper , I didn't take any pics of the drilling , but I was not to thrilled to be drilling a slotted and radiused neck , the drilling went well ![]() While I was drilling I had some dots in the oven , I got some of that FIMA polymer clay that Bill (Canadianbreed) had the thread about a while back. I drilled some aluminum angle I had with 1/8" holes and stuffed some black FIMA in the holes and baked it at 230 degrees for 30 minutes ![]() Here are the baked dots ![]() I glued them in with Titebond , after a few hours I lightly sanded them with the radius board and 320 grit , thankfully it all came out good , I am a happy man again . ![]() ![]() Oh , and the side dots will be plastic rod
Herb I don't always play guitars , but when I do , I prefer tele's , stay twangy my friends Last edited by adirondak5; January 12th, 2012 at 06:20 AM. |
#127 (permalink) |
Herb, your neck is really coming along well. It looks great (I must remember to add the 15th fret plug to the neck drawing).
I think inlaying the dots is the way to go, I plan to do the same. Painting them on may be historically accurate but inlaying has to be the better option. I like Bill's method, I'll have to remember that. I wonder if the originals were actually added after the finish, as an after thought. They probably wouldn't be too worried about them wearing off, it being just a prototype. I guess we'll never know. |
#128 (permalink) | |
Bill's clay dot method is good , especially on uncommon sizes. I agree with you that the original painted dots were probably done as an after thought .
#129 (permalink) |
Got the frets in , had to bend up some wire first
![]() Then started hammering them in ![]() All in and knipped ![]() And beveled , they are all in good , no pop ups , neck is still straight as an arrow ![]()
#131 (permalink) | |
#132 (permalink) |
Of course it is, you do pretty work!
#134 (permalink) | |
#135 (permalink) | |
#137 (permalink) | |
Like I've been saying , that headstock grows on you :D
#140 (permalink) | |
