#61 (permalink) |
That was a cool video martyn , yea , thats the headstock , that old lap steel sounded great .
Herb I don't always play guitars , but when I do , I prefer tele's , stay twangy my friends |
#62 (permalink) | |
http://www.tdpri.com/forum/tele-home...t-esquire.html http://www.tdpri.com/forum/tele-home...snakehead.html
#63 (permalink) | |
#65 (permalink) |
SSSSSSSSSubcribed,
#66 (permalink) | |
In the wrap Cut and pegged to make the blank This body will be painted. Will tint and finish the test neck in clear and show you then. Good luck on your pine hunt for this build Dave
"No trees were harmed in the creation of this message, however some electrons were temporarily inconvenienced." My Facebook |
#67 (permalink) | |
#68 (permalink) | |
I'll find my pine soon , thanks for the luck :)
#70 (permalink) | |
#71 (permalink) |
Praise the Lord!
#72 (permalink) |
Drawing Update
I collected as many reference photos of the Snakehead as I could on Google last night. All of them are the recent "Limited Edition" reissue from the Custom Shop so I don't know how historically accurate they are (I'm pretty sure the original had a 2" wide nut, the reissue is 1.65" I believe).
I found a good shot of the headstock (slightly foreshortened but usable) and compared it to my drawing: it isn't too far off. It needs a little tweaking (the radii on the corners, the shape of the blend into the nut, the position of the tuners) but the overall shape is pretty close to the reissue (the original may be different). The body looks like a standard Tele (all be it 1.5" thick) just with the different control route. Not sure if the radius on the edge is slightly larger than a 50s Tele. I'll compare in more detail when I draw the body. |
#73 (permalink) |
Mister B , that's great , there are not a whole lot of pics of the original out there , the reissued are probably true to the original. Thanks for your efforts on this , I sure appreciate it and so will a lot of others. P.M. sent.
#75 (permalink) | |
I may glue some clear pine boards up and see what it looks, feels like. I also found some sugar pine . I know I will not be 100% historically correct with this ,but I do want to be as correct as I can be , I am a little torn between going with a 1 1/2" pine blank or a glue up of 3/4" pine like the original . I am leaning towards the 1 1/2" blank. But for $20. worth of clear pine I might just do a glue up too. :)
#76 (permalink) |
Snakehead pick guard
With all of the activity on this snake build, a few guys have requested a pick guard and cutting template for their own versions -
For those who need it, here's the pdf version and a pic of the finished guard. Hope it'll help some folks with their builds - I drew and sized it from an original archival photo of a snake, and scaled it based on the 2.2' heel of the neck. Would like some feed back from those who use it to see if it's sized correctly. Hot off the press - ![]() Covering removed, ready to go -
#77 (permalink) | |
Thanks mojoatomic , I'll let you know on the size when I get the bridge , but it looks good .
#78 (permalink) |
Got the tuners today , lets see how they fit.
![]() ![]() Perfect , the Stewmac jig did its job and the tuners look great , nice snug fit.
#79 (permalink) | |
#80 (permalink) | |
Most welcome, hope it helps. Herb, I'm enjoying this build so much, I just had to contribute something. PM me your address and I'll mail you this guard template. KRamone27 - hope this helps - first file is cutting path art overlayed on snakehead and the second is the plate by itself. You'll notice some really bad parallax in the photo - hopefully I (along with some Kentucky windage) accounted for it. |
