#321 (permalink) |
Yessssss,
No string post ferrules and lots of bees wax. This is how you do it! Barncaster |
#322 (permalink) | |
http://www.tdpri.com/forum/tele-home...ml#post2768018
Herb I don't always play guitars , but when I do , I prefer tele's , stay twangy my friends |
#323 (permalink) | |
Cap
It's in the mail. You should have it by Monday at the latest. How is the pickup going? Barncaster |
#324 (permalink) | |
I am still waiting on the steel base plate and the alinco 3's from Mojotone , I have 43 awg and flat works , wax , string , that reminds me , gotta pick up some Ritt black dye and dye the string black . Do you know off hand how many wraps are on that Black Rope of yours ? I would think probably between 8000 - 9000 ? As soon as my parts get here from mojotone I'll be winding.
#325 (permalink) |
Hey Herb,
Aaron put 9600 scattered turns of 43 gauge wire on it. It also has A3 mags. The reading came out to 9.7 on the meter. I think the Fender Custom Shop Snakehead pickups were wound to about 9.4 which I believe was the approximate reading on the original. In the pine body with the big neck the tone is just incredible. Aaron makes an incredible pickup. The White Rope set I bought from him is in the surf green Tele on the wall in my video. That guitar is a MONSTER! Barncaster |
#326 (permalink) | |
I have heard nothing but good things about Aaron's pickups , quite a few folks here use them , if I didn't get into winding which is a blast I would definately look at them.
#327 (permalink) |
A quick check and final run over with some 320 grit , it's pretty nice out today , I think I can get some vinyl sealer on this today
![]() Just messing around this morning I took some Mixol #1 black and mixed with a few onces of warm water , took some of my cotton twine for wrapping coils and dipped it in the mix for a few minutes , I'll use this for wrapping the coil once I get it wound , my parts did ship from Mojotone so I should have them in a few days. ![]() ![]() ![]() Hung the dyed twine over the door to dry
#328 (permalink) | |
Phil I'm full of dust and guitars - Syd Barrett |
#329 (permalink) |
Fun thread, great read and awesome work! Looking forward to seeing the finished guitar!
Now I must go sand. I hate sanding.
Out Of Phase For Life. Lost PM's here and my contacts. PM me again for those who knows who I am talking about. |
#330 (permalink) |
Got some sealer on the body , I'll give it a few more coats , then it'll hang for a few days , get level sanded and then primer .
#331 (permalink) | ||
+100
#332 (permalink) |
Now it gets to hang out with my other unfinished projects
![]() Next on my to do list I suppose will be nuttin
#333 (permalink) |
Dude, I check this thread at least 3 times a day.
#334 (permalink) | |
Funny , I was commenting to your thread at the same time you were commenting on mine. It seems like this one is going fast , but believe me , I am putting in a lot of time on this , I look back to when I started and think , boy , it really hasn't been very long but then I think of the weekends and week nights I worked on this , I probably have more time in on this build than any other I've done. Also all the helpful advice and drawings and templates and parts folks are sending , has sped things along too , its really unbelievable , and appreciated . After a few builds you kinda get a rhythm to it and you just flow from one step to the next , at least I find I do.
#335 (permalink) |
I level sanded the body this morning and it's back outside with another coat of sealer on it , 2 more light coats today and that'll be it for sealer , then I'll start with color.
In the meantime I got the nut roughed out , After fitting in the slot I marked for the string locations and started the cuts with a .010 gauged saw , then I started the slots with the appropriate sized nut files and polished just a touch , I'll leave it like this until final setup Just started the slots with the .010 guaged saw ![]() After nut files and a bit of polishing ![]()
#336 (permalink) |
That should be good for the vinyl sealer , I'll let this sit a day or 2 and sand it lightly again , then wait on the weather and start with some color.
#337 (permalink) |
Herb, it's really coming along nicely - looks like you'll have a finish on it shortly; can't wait to see it completed! The neck has turned out incredibly well - are you nervous at all about not having a truss?
#338 (permalink) | |
I am really most curious about how it will sound , that thick neck with a 9.5k pup with the 43 awg wire, no truss rod and a sub 4 lbs pine body , after hearing Barncaster's I am pretty excited , hopefully I can get something close
#339 (permalink) | |
#340 (permalink) | |
Very nice!
"No trees were harmed in the creation of this message, however some electrons were temporarily inconvenienced." My Facebook |
