Broke my golden rule - slow build
Well, I vowed I would stick to native timber for all my builds but I'm going to break that vow with this build. It's only my fourth. I have commitment issues.
I was innocently trawling the local auction site It's olive ash burl, 14"x18". I've drawn my only musical sibling (out of 6) for the Christmas present draw this year, and he has helped me out a lot over the last year, so I'm gonna be building this one for him. The plan at this stage is to make a stage acoustic. Solid body, acoustic bridge, undersaddle piezo pickup. It'll show off as much of that veneer as possible. It's an amazing piece of wood though, theres a few faces and weird little people in there! I've also got the next consecutive pair for the back. I'm not sure how tele shaped it'll be. I'd like to try and let the veneer shape the body a bit. It seems to lend itself to a guitar shape, I just gotta remove the bits that aren't guitar, as the saying goes. I'm also not sure of the body wood. The neck will either be an existing tele neck I have, or a shredder neck (24 frets!! It won't be done in much of a hurry though. I've just moved towns and left a lot of my gear behind, so I need to visit another brother to do a lot of the work. Looking forward to getting back into it though
Phil I'm full of dust and guitars - Syd Barrett Last edited by kwerk; September 28th, 2011 at 08:15 AM. |
Beautiful timber - I have a turned feature bowl made of it. I imagine the guitar will be stunning - although I wonder how resonant the timber will be. I guess there is only one way to find out - build it!
It's only veneer, so I can build the body from whatever I want. This is something I gotta think on a little more, as it will be more critical given the type of pickup. I had a washburn solid body stage acoustic years ago, but I'm not sure what it was made of. Sounded great, though.
Phil I'm full of dust and guitars - Syd Barrett |
Practice make permanent!!!!....Perfect practice makes perfect!!! Chris B. www.neonjones.com |
I always suspected the entrance to Middle Earth was somewhere down there in NZ
As for wood for your core, I'd probably go with basswood, aspen, or luan. All light, easy to work, and you can glue or paint anything to them. Of these, I'd guess luan would be easier to get where you are. They're all cheap, paint grade woods. Luan works similar to mahogany and seems to be everywhere (I've seen shipping crates made from it). I'd also consider making it a semi-hollow, with a cheap wood core & rims covered with a birch or luan ply similar to underlayment for flooring. Considering most guitars like this are the size of a mini-jumbo, it would certainly make it lighter. And covered with that awesome veneer, geez what a fiddle In case your thinking this sounds a little too detailed to be an off the cuff idea, your right. There's a partially completed one in my storage bin These are the body designs I used for " inspiration" Dave
"No trees were harmed in the creation of this message, however some electrons were temporarily inconvenienced." My Facebook Last edited by crazydave911; September 29th, 2011 at 05:07 AM. |
"No trees were harmed in the creation of this message, however some electrons were temporarily inconvenienced." My Facebook |
Gandalf ??????????? Hell I thought it was Kwerk's self portrait!
Naaaaah .......too good looking.
"Years ago started out with nothing.....still got most of it!" |
#14 (permalink) | |
I'm still thinking hard about wood.
(Man, Freud would enjoy a sentence like that Because I've already broken my golden rule, I guess I can go the whole hog. None of the woods crazydave mentioned are available here. I could go with fijian mahogany. It'd be heavy though, but I could chamber it. I could also go with either monterey pine or monterey cypress, both of which are in plentiful supply here. I could also go down the track of staying native and using rimu, which is also being used in a build here: http://www.tdpri.com/forum/tele-home...ele-build.html It's nice looking stuff, readily available and relatively inexpensive. It's probably comparable to the cypress in terms of density. Any thoughts?
#16 (permalink) | |
That is fantastic, MCT. You were the first person I thought of when I pushed the "buy now" button for that veneer. Expect your brains to get a pickin'
#17 (permalink) | |||
A friend and I broke down a shipping container ( had contained computer desks, office furniture, etc) about 4 yrs ago, almost big enough to live in, that was solid luan, plywood & beams. Oh yes, it was postmarked Auckland Quote:
I guess the moral of my sad (and always rambling) story is, unless the body is on the smallish side, or the wood light,or the body thin, these things gain weight like a pregnant cat Dave
#18 (permalink) |
I'll bet you anything you like those desks weren't made in New Zealand. I could be wrong.
I've done a search, and while I can find a Brazilian surfer call Luan Wood Rimu is around 650kg/m3, which is comparable to white ash, longleaf pine or african mahogany. Quite dense I suppose. The monterey cypress, known here as macrocarpa, is around 490kg/m3. comparable to Eastern red cedar, lighter doug fir. I was quite a ways out in my estimate of the rimu matching this for density. The monterey pine, known here as "radiata pine", is the most prolific and avilable timber in NZ. It's standard building wood here. It has a density of 520kg/m3. Comparable to red gum, black ash, and heavier doug fir.
#19 (permalink) |
Btw, I'm not thinking anything as large on outline as a traditional acoustic. It'll be closer to tele shape, or some kind of LPish-teleish-ish-ish shape according to what the veneer seems to be saying to me (people may say I'm mad for talking to wood, but in this case, it's talking back
#20 (permalink) | ||
FWIW, the cypress followed by the pine sound like your lighter options, but I wouldn't write off the rimu. You know, and I know, a lot of your denser woods vary. I've seen mahogany boards I could barely lift, and one time, one so light I nearly threw it into my windshield as I was expecting much heavier Dave
"No trees were harmed in the creation of this message, however some electrons were temporarily inconvenienced." My Facebook Last edited by crazydave911; September 29th, 2011 at 11:37 AM. |
#22 (permalink) | |
#24 (permalink) |
Radiata Pine is fine for making bodies. It's got a nice grain too if you get a clear piece.
Would set you back about $10 too, which is handy. And it doesn't need grain filling. And when it was cut down one of these was put in its place.
You need to roll the dice to be in the game. |
#25 (permalink) |
Yup, though I may be compromising my principles, I'd be very happy in the knowledge that I'd be using sustainable resources. This would apply to either of the exotics I'm considering. Not so much on the rimu, but recycled rimu is readily available, and a doorstep or stair tread would make a good base for a body. I could use recycled kauri too (just the regular 2000 year old stuff, not the prehistoric stuff), come to that.
#26 (permalink) | |
"If it ain't broke, Mod it till it is"
![]() "Born from the junction of form and function...It's the Hammer of the Honky Tonk Gods" |
#27 (permalink) |
Well much as I'd love to buy this, I can't come near to affording it...
http://www.trademe.co.nz/building-re...-410393515.htm Might be a little more than I need to buy for the build though...
#29 (permalink) |
Hey Kwerk ......Seriously mate I'd think hard about just matching them as near to perfect as I could, fit a backboard, and pop the grain, stain and frame them and put them behind glass.
If you have the next set as well, you'd have something unique. I'm sure you could construct a magnificent set of frames for them. DC
#30 (permalink) |
Gandalf's Family
Just remembered what that veneer reminded me of. In Hangzhou China there is a museum with hundreds of golden statues of the disciples of Buddah and there are several there which look like Gandalf's relations, especially this one which has a God etc. on his head as well.
DC
#31 (permalink) | |
#32 (permalink) |
Well, there you go Dave, I did decide I couldn't part with the old man, so I relented and bought yet another pair from the guy.
![]() I got some figured straight olive ash as well to go around the sides. I'm gonna go with a laminated and weight relieved pine for the core as it's cheap and light. It'll have 3 a side black tuners and black binding. The original pic (sent by the seller) was at good resolution so I was able to correct for the camera angle and get good shots of the other pieces. More faces, and some pretty amazing other stuff going on too. ![]() Chewbacca? ![]() And finally, the original pair which was a little too distorted in the original to get more detail, but I "oiled" the image i did get from it in Photoshop to get an idea of how it might pop. ![]() That's either the reverse side or he's stuck that sticker on there since he took the original auction photo. As far as shape goes, I'm still wanting to wait on the veneer to get here before I make a call on it, but I'm leaning towards a tele/coronado kind of shape. Has an almost dreadnought feel to the bottom of the guitar without the size. This photochop is a quick sketch but you get the idea. ![]() Yes, it's Antigua. I still like it. I'm also going to wait on the veneer before I determine scale length and fret numbers. I want to look after whichever "old man" ends up on the front, and the bridge will need to be clear of most of his head. Then again, I kind of like the idea of the bridge being incorporated with the head somehow. I'll have to wait it out. Only a couple of days.
#33 (permalink) |
Phil it'd be a crime to wack that string retainer over the old fella. Go with a wrap around to show him off.
#34 (permalink) | |
#35 (permalink) |
Years ago I had an SBT-21, at the bottom of the page in this ad.
![]() It sounded great, considering what it was. A solid body with an acoustic bridge, and piezo. This is the general idea for the build, but without the controls on the front, and without the pointy bits. This is the SBF-80 from a few years later, which is rather more pleasing to look at, as there are few things sadder than a tele with a pointy headstock..
#36 (permalink) |
I agree about the pointy bits and really dislike those angular Washburn headstocks. I have just completed a strange looking neck with some features I intend to make my stock style for future builds and thinking about putting it on a loosely based version of a Maton B250 T style copy from the seventies, very rare and only 300 made. Will also trial a different construction method.
If you have too many of those veneers now, I could dispose of some for ya!
"Years ago started out with nothing.....still got most of it!" Last edited by Davecam48; October 3rd, 2011 at 01:57 PM. Reason: forgot a pix |
#37 (permalink) |
I've made a start on the body design. It's a crossover between a coronado, a junior and a tele. I still have to refine and clean up the horns a little, but this is the basic idea. I've overlaid it on some LP Jr plans to try and utilise the shorter scale, so as to give me more clear area behind the bridge.
![]() I still can't finalise the shape until I get my preamp, as it has a profiled base that I'll need to work to. I'm still going to try and go ahead and rough out the basic blank idea on the weekend though, and try to make a start on the scarf joint for the headstock. Can't wait.
#38 (permalink) |
Oh my, that's gonna be sweet!
#39 (permalink) |
Ok, here's the final design. The body's going to be about 2" thick, so I will likely have a deeper neck heel than a regular tele body, but will still go with a bolt on neck so I can have a heel adjust which I prefer. The thicker body will allow for a side mounted installation of a low profile 4 band EQ.
Phil I'm full of dust and guitars - Syd Barrett Last edited by kwerk; October 8th, 2011 at 05:50 AM. |
