what to do with roadside lumber
Build a tele with it! I'm not sure what it is, except it's some sort of pine and very dry and lightweight. I've ridden my bike past that board at least 50 times, and I finally decided to drive back and grab it. It's not thick enough after planing flat, so I capped with .25" poplar front and back. It'll get a paint job, so the greenish ugly coloring of the poplar and the glue line are not a problem.
I sanded right to the line, so routing the body shape was easy, very minimal burn spots, and no tearout |
#2 (permalink) | |
the now mandatory =====> |
#6 (permalink) | |
I LOVE the ROSS. I don't have lots of tools yet, so I really appreciate the versatility of that machine. |
Rolled out the drill press first thing this a.m. and finished drilling. I have a bit more sanding to do, then I'm going to spray it with some shellac sanding sealer. Turned out OK, but somehow one of my ferrule holes was off a bit
I'm going with G60syncro's suggestion, semi-transparent sides, faux binding front and back, and painted top and back. I'm thinking about cherry red sides and either candy apple red or duplicolor metal specks red for top and back. |
Yesterday afternoon I got the headstocks planed down and the truss rod channels routed. Unfortunately, I routed too deep on the birch neck. I think I might try routing all the way through and glue in a filler strip, then re-route, but then I'd have skunk stripe on the back side. Or, I could just route a flat channel to the furthest depth I went all the way across and make a filler strip for that. I'll take suggestions!
#14 (permalink) |
Not too much progress. Got the fretboards trimmed up, made one of the truss rods, and got a coat of sealer on the body.
I've heard horror stories about allergic reactions to cocobolo, so just to play it safe I wore a long sleeve shirt, goggles and my respirator. The darker brown board on the maple neck is mukushi, an African teak. LMI gave it a 2nd grade, but I think it's nicer than the cocobolo boards they sent. |
little bit of finishing progress. I was going to paint the top and back, but now I'm starting to like the grain and coloring of the poplar. Maybe use the brownish amber color I used on the sides along the edges of the top and back for a burst look?
#16 (permalink) | |
Herb I don't always play guitars , but when I do , I prefer tele's , stay twangy my friends |
#18 (permalink) |
Not much progress on the builds, got the truss rods in, fb's glued, and headstock transition. Slow going...
Back to the bodies, though, today the weather calls for 90 deg F., low winds and 32 per cent humidity around noon. I think it's a good day to spray clear lacquer on my lunch hour...or is it? Is that too hot? I've never sprayed this stuff in that kind of heat. Let me know what ya'll think. Craig |
#19 (permalink) |
Poplar is just fine for bodies! I scavenged a nice poplar board that was being discarded. 8/4 thick (and then some) and wide enough for t-style body with no gluing. It's amazing what people throw away.
Not sure why poplar's not more... um... popular. ![]() Rear rout for either a Cabronita/Esquire or maybe a short scale bass.
"Let's take everything we think we know about solid body electrifying guitars and throw it out the window. Let's start over." ---Leo Fender |
#20 (permalink) |
Well, I got my answer. The heat was fine to spray in. Two coats went down REALLY nicely. but....my garage was hot, and I didn't want to close it up with the fumes and all, so I put it in the shade under my patio overhang, with the paint stick in the umbrella holder of my patio table, went back to work. Work ran late...By the time I got back home the sun had been beating on it for at least an hour, the thermometer was reading 101, and the side that was in the sun had developed several blisters.
I'm guessing I'll have to sand it back to the sealer, unless anyone can think of what else I might try? |
