Help with circuit for 3-pickup tele please?
Hi everyone, this is my first post on this forum. I'm based in the UK, and am currently building a tele partscaster, and thinking about the best circuit to use for the pickups. The guitar will have the standard tele pickups (a Tonerider Hot Classics set) plus a middle strat type pickup, which is RWRP to the neck pickup. So the neck plus middle, and neck plus bridge combinations will be hum-cancelling. I have fitted an extra mini-switch (an ON-OFF-ON, double pole, triple throw) to the control plate, in addition to a standard strat type 5 way switch.
I would like to be able to get all 7 possible parallel pickup combinations i.e. the normal 5 "strat" ones, plus neck and bridge, and all 3 pickups together. But there are 2 more I would like to have if it is possible: neck plus middle in series, and neck plus bridge in series. So I'm wondering if anyone has a way to achieve this? Any ideas or help would be gratefully received - hope this is not too technical a question to start my life on the forum! Assuming I get through the building process in one piece I hope to post a pic or two of my tele when it's complete. Thanks for reading, cheers! |
I guess this was maybe not such a good question! I've been thinking about it myself, and can't come up with an easy answer. I may look at fitting a 5-way super switch to expand my options - I'm pretty sure with this I could get what I'm after in terms of pickup-switching. It is a bit bulky though, so I may have to carefully remove a little wood from the side of the control cavity. I'll have a think though, and cheers to everyone who took the time to read my question.
I have my Tele wired w/ 3 pickups. The neck and bridge are wired w/ a 4 way switch so I can get them in series or parallel. The middle pickup is wired to a separate vol. pot so it can be blended w/ the other pickups or used on its own. It can only be combined in parallel. I guess I could have used a push/pull pot for a series option but I'm not crazy about them and 9 useable tones is enough for me.
#4 (permalink) | |
I'm sure I'll figure something out though, given time, cheers! |
The usual wiring for a Nashville is to use a strat 5-way selector and standard tele vol+tone 2-knob controls.
There are many variations and options. One such is to swap middle and bridge connections so you get neck neck+bridge bridge bridge+middle middle Do note that tele pickups ate opposite wind/pole to strat pickups, so you need a neck or bridge strat pickup, not a middle strat pickup on a tele - to give the hum-cancelling effect of the strat's RWRP middle pickup on a strat.
#6 (permalink) | |
PJ |
#7 (permalink) | ||
What I did on one of my builds is sort of the Brent Mason Tele approach - to just use a 3-way strat/tele switch and then wire up the middle pickup through an additional 500k pot straight to the output of the switch. That way the amount of the middle pickup is dialed in and that works really well to get the most from the 3 pickups in parallel. I suppose you could add a switch to put the 2 tele pickups in series with that config as well.
Here's a snazzy schematic from Terry Downs that I used on mine: http://terrydownsmusic.com/archive/b...lel_wiring.PDF Don't be confused by the series/parallel switch - you can leave that out with a standard strat pickup for the middle. Just add a series/parallel switch for the outside pickups. |
#9 (permalink) | |
thinking out loud here, and i'm no wiring expert, but could you possibly do a five way strat normal circuit with the neck pickup on a push pull pot so you can pull it up to turn it on when your in the bridge position (thereby getting neck and bridge) and then putting a push pull on the tone pot for series/parallel wiring?
#11 (permalink) | |
