Musikraft Set-Neck Builds?
They offer a bunch of options that might make for a very nice guitar.
Anyone build off of a Musikraft set neck body? How was it? Any pics? Thought of a few different configurations that might be cool: George Lynch "Tiger" Super-Strat 50's Tobacco 'Burst Strat w/ Floyd Rose and Bridgebucker Esquire Blackguard w/ Bartolini E90 https://www.musikraft.com/product-info.php?pid118.html |
I would have though more people would have tried these. It might make for a nice combination of the best from 50's Fender up to today.
I've watched some clips of set-neck Teles and they still sound like Teles. |
They look interesting. The last three of my T-style builds have featured set necks, and I don't think I'd want to go back to a bolt on. Personally I prefer to build them myself though, but if you can't, or don't want to, these look like a great option.
#6 (permalink) | |
I certainly could use a Tele with a more modern take that preserves some of the 50's technology lacking in today's store bought guitars. Working/tooling up to make my own bodies and necks, but have been devoting my shop time to another pursuit. |
#7 (permalink) | |
Why build it if you can buy it? Make it special! |
I don't think there is anything inherently better about a set neck design, on the last tele I made, I made the neck a bit wider and a bit longer and moved the pocket back by the same amount - ~.4" - and then used an Ibanez style AANJ neck joint: I think that change makes it playable on all strings up to a 22nd fret and sustains quite well... That's the route I went to modernize the Tele I made, worked out really well and I'll use that on my next build too - which is likely to be a Les Paul with a bolt on neck and a strat-style forearm contour - just have not worked out how I would do the binding (or not).
![]() ![]() Being able to remove the neck makes all of the fret/neck work easier to do, and to keep the frets in top form. Also, if the neck pocket and the neck fit really well the joint is very stable, so I don't really see the advantage of a set neck. |
Nice of you to post a pic of you beautiful guitar.
I guess for me it's a feel thing; the way the neck blends into the body on an ESP, Jackson et al. Though the idea is of blending old aesthetics with new, I'd feel a little dirty putting an active pickup in an otherwise traditional Tele. |
#11 (permalink) | |
#13 (permalink) | |
I used a 3/8" Aluminum pipe segment to line the truss access, I used 1/4" Aluminum rod for the dots, and I used a much thicker Aluminum pipe for the jack connector lining. The neck wood is West-coast Wild Cherry - and the fretboard is Madrona - the body is Oregon Ash - I had a NW US native wood theme goin' there. Also, the bridge is made out of Aluminum angle the nut is made out of a scrap Aluminum piece from making the bridge. Here's the whole build thread - the only thing I did not redesign (including most of my jigs) - or borrow a re-design from forumites - is the headstock. http://www.tdpri.com/forum/tele-home...ge-thread.html Here's a summary: http://www.tdpri.com/forum/3373703-post457.html Here's another couple of pics of the head: ![]() ![]() ![]() Same kind of idea on the body: ![]()
#15 (permalink) | |
Mojo, thought the grain looked familiar, have some cherry growing here. I love the mix of aluminum and local wood. Reminds of those Kirsten tobacco pipes made in Seattle, really does have a NW thing going on. Taking a look at your thread... Last edited by batsong; August 21st, 2011 at 02:43 AM. |
#16 (permalink) |
Two reasons: Much easier to build and it means you can carve the heel much moreso than if you're restricted by having to site the neck screws.
![]() ![]() The downside would be that if you ever needed to take the neck off it is a PIA, but, as yet I've never felt the need to remove the neck from any of my guitars. I'd agree with mojotron that there isn't anything inherently better about a set neck design. It is just a matter of personal preference. |
#18 (permalink) | |
My two cheapest store-bought guitars are set-neck... To me, I like that the bolt-on allow a direct wood to wood contact (instead of having glue in between the neck and body) but that's probably irrelevant. Set-neck and neck-through do allow for extremely nice neck to body transition, though Les Paul are set-neck and have pretty bad upper fret access! But people expect them to be "just like in the 50's" so Gibson has to abide!
#19 (permalink) |
Beautiful work, davmac! That transition from body neck is quite elegant.
What species of wood are you using? The Tele looks to have a (maple?) top. How far back do you mortise the neck? How do you think the set-neck design affects tone? Badside, Just watched GE Smith's 50 Watt Fuse DVD, he plays a trussless Esquire throughout it, and I could not get enough of it's tone! A good reason for creating replicas of guitars like early pine Esquires or Broadcasters and the like. I think the only way I can get one of these is to make one, or have someone on TDPRI to make one for me. I definitely would not consider any set-neck design an option over a bolt on, the guitars at Musikraft are more like davmac's posted above. Which are similar to a Jackson Soloist, which I would consider more modern. |
#20 (permalink) | |
Here's the top... ![]() ...and a picture of the tenon before the cap went on... ![]() I have also made a Tele with a set neck tenon that was the same size as a standard Tele neck pocket and that works fine too. And it maybe my duff ears but I cannot tell the difference in sound between a thru-neck, set neck and well executed bolt-on neck. I suspect that any perceived differences are all in the mind (which is no less valid a difference if it makes you play better). |
