![]() Tele-Afflicted
P90 location
Hi guys,
Who here would have a "bridge" location dimension for a P90 pickup in a standard Tele body? Also what is a standard pocket depth as well. Bill |
I just went through this a few weeks ago, did a lot of research to find out, pickup placement is a compromise everywhere. Some compromises are better then others, so I ended up placing the pole pieces on the line perpendicular to the strings that the center of the low E pole piece in a stock tele bridge is on. That put the bottom edge of the route (the one closes to the bridge) 1 11/16" from the center line of the string through holes. I made the pockets 11/16" deep
any reason a P90 is put in square to the strings at the bridge?..
most other single coils are slanted at the bridge... I thought I'd slant my bridge p90 ... being a single coil too... it's a thinner body...I could have gone a bit deeper 5 mm or so... to give the wires more room below PU's, plus I drilled a hole down the centreline for the neck PU wire to go into the bridge pocket and then to the yet to be routed control cavity. .instead of a 45 deg hole/rout from the neck pu to control cavity as per normal... wtf!?.. is that about?... a stupid extra rout I reckon.. |
.. these line up OK on an angle.. I guess...
both pu's have around 50mm pole spacing.. the string spacing at the bridge is 53mm... maybe more bass action further away from the bass E side saddle?. that could be one sonic difference with location/angle, I'll have to make a similar body and try the bridge PU square to see/hear for myself.. |
#9 (permalink) | |
formerly "Big" Mike Simpson
The bridge pickup is in the same location on both of these. If you want the measurements for the location that I use let me know and I will measure my template for you. Here is one with a Wilkinson half bridge ...and here is one with a Gotoh stop tail and TOM bridge.
http://www.hoodoocasters.com/ http://www.facebook.com/TheHoodooCasters http://www.reverbnation.com/thehoodoocasters https://twitter.com/hoodoocasters Last edited by Mike Simpson; July 30th, 2011 at 07:13 PM. |
(sorry, image didn't import here) Sorry to also chime in off-topic, but Big Mike, that is a very beautiful guitar.
--Rick A dog teaches a boy fidelity, perseverance, and to turn around three times before lying down.--Robert Benchley |
Thanks R. Stratenstein
That was my 2011 build challenge entry, here is a link to the build thread if you are interested. http://www.tdpri.com/forum/2011-tdpr...ge-thread.html |
