Old June 26th, 2011, 04:07 PM   #1 (permalink)
Muzikp's Avatar
Build begins - 72 deluxe Jaguar type thing...Jagster well call it.
I picked up this piece of black walnut and my intentions are to build three of these 72-deluxe-jaguar... er, Jagster's out of it.
Started with a full size plot of my plan which I drew in CAD. I had a variety of drawings, pdf's etc that I found here at TDPRI to use as a reference.
Glued it to a piece of 3/4" I had laying around (actually my neighbor gave it to me but that's more detail than we need) and rough cut it on the bandsaw. I forgot to take a picture here so this one was staged sorry
Then it was on to sanding the template to the line on the drill press. I also forgot to take pictures where I cut out the cavities with a jigsaw, but really that's not very exciting so...
So that's about as far as I've made it so far. I need to finish sanding the template and get it all perfect.
I'll start cutting up that walnut this week and gluing it together for 2 piece bodies. More to come...as usual input and advice is welcome, please let me know where improvements to my process could be made.
I will send out the CAD and PDF to those who wanted it this week.
Muzikp is offline   Reply With Quote
Old June 26th, 2011, 08:07 PM   #2 (permalink)
Holy crap. I LOVE this!
redddog is offline   Reply With Quote
Old June 26th, 2011, 08:11 PM   #3 (permalink)
Muzikp's Avatar
I finished the template, then I decided to make a prototype body before I ruin all that expensive walnut. Here's the prototype so far.
Old June 26th, 2011, 08:13 PM   #4 (permalink)
Muzikp's Avatar
I'm thinking about making the slot from the pickups to the control cavity bigger on the real ones. That looks small to me. Waddya think?
Old June 26th, 2011, 08:56 PM   #5 (permalink)
Shepherd's Avatar
Those are plenty big for a couple of wires, you could even just use a 1/4" drill bit instead.
Have you seen this build? Lotta a cool stuff over there.
http://offsetguitars.com/forums/view...hp?f=8&t=41268
Shepherd is online now   Reply With Quote
Old June 26th, 2011, 10:13 PM   #6 (permalink)
crane550's Avatar
Nice! Look forward to seeing this play out! I am about to start a Jazzmaster for myself...really looking forward to it.
"Smithers! This isn't rocket science! It's brain surgery!" -Montgomery Burns
crane550 is offline   Reply With Quote
Old June 26th, 2011, 11:30 PM   #7 (permalink)
Jupiter's Avatar
Just curious, but what are you planning to do with that "prototype" when you go on to the walnut?
If only we could use our evil powers
For the good of mankind.
--Tito and Tarantula
Climbing Mt. Stupid since 1962
Jupiter is offline   Reply With Quote
Old June 26th, 2011, 11:47 PM   #8 (permalink)
mgdesigns's Avatar
How did you get the interior cuts with just a band saw? If you did, that's a trick we can all use, for sure.
Old June 27th, 2011, 12:10 AM   #9 (permalink)
DesmoDog's Avatar
He said jigsaw, not bandsaw...
P.S. I'd love to get the CAD files for this. 24" scale length?
-Craig
http://www.teamyikes.com/
DesmoDog is offline   Reply With Quote
Old June 27th, 2011, 02:23 AM   #10 (permalink)
Casual_Reader's Avatar
if you think that switch might be in the way, there's always the option of a rotary switch to the south of the neck p'up with an old selector knob.
though it's convenient when all the electronics can be assembled on the pick guard and dropped in and screwed down. A bit wider channel would make that less tedious.
Casual_Reader is offline   Reply With Quote
Old June 27th, 2011, 02:40 AM   #11 (permalink)
Muzikp's Avatar
I'll send you the cad file. There's lots of other interesting things in the cad file. Standard tele versions, 72 tele deluxe drawings, tele and strat neck drawings, jaguar, jazz, telemaster, a les paul tele type thing etc. etc.
PM me your e-mail.
This is a 25.5 scale, but with the cad file you could easily make it 24". You'll have to massage it a little to move the bridge but it could work.
Old June 27th, 2011, 02:52 AM   #12 (permalink)
Muzikp's Avatar
Funny thing about my prototypes, they will likely turn out better than the predecessors. You may not be impressed after I tell you that's doug fir that I salvaged from my neighbors 80 year old floor joists. You can see a couple of nail holes on the front of the Jagster. I have a whole garage full of this wood. I put up a post a while ago asking what people thought of making bodies out of it. I got mixed opinions (go figure it's the internet) but in the end people said go for it, so I did and I'm glad.
Here's the tele body, I need to take some current pics of it but you get the idea. It's full dimension wood, very dry and incredibly light. This one is 3.9ish pounds.
Old June 27th, 2011, 03:03 AM   #13 (permalink)
Muzikp's Avatar
Good point, I'm all for less tedious. Wider it is then.
Now I need to figure out how to do the contours, I've never done those before, that's mostly why I wanted the prototype. My plan is to sketch the shape of the contour on and grind away everything that doesn't belong...how hard can it be
Old June 27th, 2011, 10:41 AM   #14 (permalink)
mgdesigns's Avatar
Sorry about no seeing the note regarding using a jigsaw. My bad. These builds from the old floor joists look great, and I bet they'll sound great too. Nice thread, and good craftsmanship. Thanks.
Old June 27th, 2011, 04:13 PM   #15 (permalink)
Muzikp's Avatar
So I quickly got overwhelmed by the amount of people wanting the cad file and pdf. I had no idea so many would be interested. Rather than e-mail it 50 times here is the link to download the CAD file.
http://www.fifty5five.com/tele/jag/guitar-cad-file.dwg
There are a lot of different style guitars and concepts in this file. Here's a screen capture of some of it
Here is a link to download the PDF of the jagster plan for this build
http://www.fifty5five.com/tele/jag/jagster-plan.pdf
Old June 27th, 2011, 10:14 PM   #16 (permalink)
justin72deluxe's Avatar
Is there somewhere to get autocad for under $4,000?
justin72deluxe is offline   Reply With Quote
Old June 27th, 2011, 10:29 PM   #17 (permalink)
Mojotron's Avatar
I totally agree: I love "softwoods" they generally tend to be rigid while being relatively light and hard enough for making a great guitar body. Also, I tend to do my best work when I'm trying something new - which I try to do a lot..
I have some wide railings that are about 40 years old that I replaced recently - those are going to make some great bodies.
Old June 28th, 2011, 12:11 AM   #18 (permalink)
Muzikp's Avatar
I used Google Sketchup for a guitar body template drawing once...emphasis on the "once". But it is free. I could import the file above into Sketchup for you if you like.
You can get AutoCAD lite for a lot less than the full program and it will do what you need for this purpose.
Old June 28th, 2011, 10:40 PM   #19 (permalink)
Yep. I think that's all I'm allowed to say. Basically get it the same place everyone gets every piece of graphics software.
Citizen_Insane is offline   Reply With Quote
Old June 29th, 2011, 12:15 AM   #20 (permalink)
Muzikp's Avatar
Didn't do much on the Jagster today. I decided to get the 53 Tele body ready for paint instead. How do you guys drill your input jack holes? This was all I could come up with, my drill press rotates, swivels, spins and on occasion I even use it to drill a hole. I clamped the body to a make shift jig and lined everything up and then hoped for the best. It came out really well I think.
