Old March 1st, 2011, 11:12 AM   #1 (permalink)
OpenG Capo4's Avatar
Lumber dimensions for body blanks
So I'm looking over my local Craigslist and all the good lumber (especially the reclaimed stuff) is in widths of 6 or 12 inches. After planing/joining the rough-sawn wood it would be considerably less. How would one build a Tele body from this stuff, given that the lower bout is 12.5 or 13" ? Do those of you who build using reclaimed stuff just shave the lower bout dimensions down to less than 12" ?
Found some heart pine from 1876 locally, its available in 10, and 12" widths. Just not sure how I'd join it together for making a 12.5 or 13" wide body without lots of scrap.
OpenG Capo4 is offline   Reply With Quote
Old March 1st, 2011, 11:25 AM   #2 (permalink)
a typical body blank measures 14" wide 20"long and 1-3/4" thick
KRamone27 is offline   Reply With Quote
Old March 1st, 2011, 11:30 AM   #3 (permalink)
crane550's Avatar
I get my blanks 14x17, or 7x34 if I am making a two piece. Never been to small yet.
Alex
"Smithers! This isn't rocket science! It's brain surgery!" -Montgomery Burns
crane550 is offline   Reply With Quote
Old March 1st, 2011, 07:35 PM   #4 (permalink)
guitarbuilder's Avatar
[QUOTE=OpenG Capo4;3122500]So I'm looking over my local Craigslist and all the good lumber (especially the reclaimed stuff) is in widths of 6 or 12 inches. After planing/joining the rough-sawn wood it would be considerably less. How would one build a Tele body from this stuff, given that the lower bout is 12.5 or 13" ? Do those of you who build using reclaimed stuff just shave the lower bout dimensions down to less than 12" ?
You cut the wood narrower so that you end up with a body about 14" wide or so usually in 2 or 3 pieces.
Old March 1st, 2011, 07:58 PM   #5 (permalink)
gitlvr's Avatar
Three piece body blanks work just fine. I build with what I can find and glue it up however I have to in order to make it work.
Mike
The only thing necessary for evil to thrive is for good men to do nothing.
gitlvr is offline   Reply With Quote
Old March 2nd, 2011, 03:34 AM   #6 (permalink)
When i cut my wood log this my body blank size.
one piece = 5 cm x 50 cm x 35 cm
Two Piece = 5 cm x 50 cm x 17 cm
Three = 5 cm x 50 cm x 12 cm
taekmanis is offline   Reply With Quote
Old March 2nd, 2011, 04:15 AM   #7 (permalink)
melomanarock's Avatar
you could make a 3 piece body with 6" board or 2 piece with a 12". If you need to choose one or the other I would go with the 12". A 24" inch body blank is pretty oversized but you can make sure you dodge cracks and knots.
can buy boht? glue a 6" piece to a 12" one.
melomanarock is offline   Reply With Quote
