Old February 11th, 2011, 11:40 PM   #1 (permalink)
Oversized Tuning Holes
Just ordered a Mighty Mite neck. Not expecting much, I was pleasantly surprised. Thought it would meet my needs, until I realized the 3/8 drilled tuner holes were really 10.5 mm. That doesn't help me with my 10mm tuners. He's offered to take it back. I was expected to do some fitting on the tuning holes, but not filling!!!
So what do you think? I think the tuners will fit sloppy, but is this standard procedure on this? I've only worked on a couple of other guitars, but the other tuners have been a snug fit. So, send it back, let the tuners fall as they may, do some sort of shimming around the body of the tuners, or fill and drill?
Thanks in advance!
CGurn
CGurn is offline   Reply With Quote
Old February 11th, 2011, 11:58 PM   #2 (permalink)
piece of ash's Avatar
Send it back... and tell the idiots to publish ACCURATE drawings and dimensions.
I deal with this all day... because "marketing" has been handed over to some "person" wearing artificially aged jeans... that doesn't know an inch from a foot.
piece of ash is offline   Reply With Quote
Old February 12th, 2011, 12:03 AM   #3 (permalink)
mijstrat72's Avatar
Did you specify what size tuner holes you needed? If so send it back, if not, then it's your problem. Just get some adaptors from GFS. It happens all the time, no biggy.
If ya wanna be dumb...ya gotta be tough.
mijstrat72 is offline   Reply With Quote
Old February 12th, 2011, 03:49 AM   #4 (permalink)
Yeah if press in get some adapters
If screw in 0.5 won't make a difference really once they're tight
slapshot is offline   Reply With Quote
