Old January 27th, 2011, 08:11 AM   #1 (permalink)
nicer's Avatar
Good bridge PUP to pair w/ a P-90?
Anyone have a good recommendation for a bridge PUP to be paired with a neck P-90?
This is my first post here; hi!
I've got my heart set on building a new tele mostly b/c I can't find a guitar with everything I want that I can still afford.
I was hugely inspired by stumbling on warmoth and realizing you can make a decision about pretty much everything.
This guys P-90 jazz tone is, incredible,
http://www.youtube.com/watch?v=KKxDpBAARZc
I'm debating right now between doing two P-90s or keeping a regular single coil in the bridge for a bigger tone spread.
Wondering if anyone has suggestions for a bridge pickup that could keep up with a vintage P-90, like the Duncan SP90-1??
I really need to nail this first time around - make a really versatile, useable and durable daily player.
Great forum you guys have going here - happy to have found it. Have already read a ton of your stuff, so thanks.
Rya
nicer is offline   Reply With Quote
Old January 27th, 2011, 08:48 AM   #2 (permalink)
formerly "Big" Mike Simpson
Mike Simpson's Avatar
Mike Simpson is offline   Reply With Quote
Old January 27th, 2011, 10:00 AM   #3 (permalink)
paulskirocks's Avatar
I say all P-90s...
paulskirocks is offline   Reply With Quote
Old January 27th, 2011, 10:17 AM   #4 (permalink)
I would go twin P90 from choice .I have a P90 neck and a standard tele bridge and it all sounds good but is a compromise as you have to decide what pot value to put in .Ideally a 500 for the P90 and 250 for the bridge .I have Toneriders and it all seems oK with 250 pots but maybe the p90 would be a bit warmer and jazzier on 500 .There also is a volume difference .The in between sound is fantastic so a keeper ..
musicalmartin is offline   Reply With Quote
Old January 27th, 2011, 10:18 AM   #5 (permalink)
fezz parka's Avatar
If you go tele style with the bridge, Duncan Broadcaster, CS Nocaster or CS Texas Special will do nicely.
Old January 27th, 2011, 11:04 AM   #6 (permalink)
e-merlin's Avatar
I have a DiMarzio PRE-B1 in mine. It's great. I'm not sure what P-90 is in there now. I got it in a pawn shop for $5, but it's a good match.
I have one of Fezz's P-90s going in as soon as I can find the time. Will report on that combo when I get it dialed in.
'tone is in the underpants'
Old January 27th, 2011, 11:08 AM   #7 (permalink)
octatonic's Avatar
Harmonic Designs Super 90.
It is a P90-ish tone in the regular tele bridge pickup case.
http://www.jamesrichmond.com
Old January 27th, 2011, 11:13 AM   #8 (permalink)
+1. Love mine. Hot but not an over wound sound.
Now go do the voodoo that you do sooo well...
Booman is offline   Reply With Quote
Old January 27th, 2011, 12:17 PM   #9 (permalink)
hockeygoon's Avatar
Two P-90s is my vote. I have a GFS pair on my jazzmaster build and they sound awesome, especially in the middle position.
hockeygoon is offline   Reply With Quote
Old January 27th, 2011, 12:25 PM   #10 (permalink)
If you're completely undecided, then here's another one: Jason Lollar Charlie Christian set. They are perfectly balanced in volume, they sound great together and separately. Not often described as P-90 sounding, but I'd call them the "Best Sounding P-90's That Aren't P-90". You won't find a better jazz tone from the neck, and the bridge doesn't take your head off the way other Tele bridge pickups often do.
FenderLover is offline   Reply With Quote
Old January 27th, 2011, 01:16 PM   #11 (permalink)
newtwanger's Avatar
I tried the single-coil bridge and P90 neck route and since one is happy with 500k pots and the other 250k, I didn't end up with something I really liked.
I put a Duncan lil '59 in the bridge, 500k pots and all is swell.
newtwanger is offline   Reply With Quote
Old January 27th, 2011, 02:12 PM   #12 (permalink)
I have 3 P-90's and I used 250k pots... It sounds great.
Old January 27th, 2011, 02:15 PM   #13 (permalink)
BradKM's Avatar
Third vote for an Harmonic Design Super-90!
"Go Team Venture!"
BradKM is offline   Reply With Quote
Old January 27th, 2011, 11:05 PM   #14 (permalink)
nicer's Avatar
Great - thanks for all the input - I shall now commence hunting for sound clips of your recommendations on youtube.
I hadn't really considered pots values...
