Telecaster Harp Guitar
A while ago, I made a harp guitar that was just to unwieldy and I never used it. Over the past year, I decided to rebuild it completely. I'm really happy with the results.
It started out like this: ![]() and now it looks like this: ![]() I documented the rebuild on another forum (didn't think anyone here would be interested). You can see it at: http://www.jpfolks.com/forum/ubbthre...e/1#Post845289 For all those that want to hear, I also just finished uploaded an audio demonstration. Plugged the harp guitar and a cheap vocal mike directly into the computer, used Audacity for the first time, and winged it. ENJOY! http://soundclick.com/share.cfm?id=10126475 Don't listen too closely at the Bmin chord which sounds slightly out of tune.... |
Dr Tom,
What kind of acoustic pickup did you use at the bridge, and can you give photos of how you installed it? I loved that sound. I don't expect to ever play one of these harp guitars, but the bass notes certainly did add to the music. Mike |
#9 (permalink) | |
The bass/harp strings use a telecaster bridge pickup screwed right into the body. The angle of the pickup was straightened out a bit to line up with the slightly wider string spacing. |
#11 (permalink) | |
Mike |
Turmite - what I call the acoustic pickup is built into the saddles of the bridge. Each saddle has a wire that goes to a PCB inside the electronic cavity. I call the dream 180 the "bridge pickup" and the split fender the "neck" pickup. I hope that helps. Keep in mind that you are also hearing the instrument plugged directly into the computer. The electric pickups were really designed to be played thru a guitar amp. Maybe one day I'll get to do some serious recording and perform with this one.
