anyone good at reshaping strat neck headstock to tele shape?
i have a beautiful maple strat neck i want to get reshaped to tele for a build, anyone do that on the cheap?
thanks! |
as far as the heel goes i just test fit it on a tele body i have and its a decent fit as is. if i have to reshape it a bit i can do that no problem but the headstock is what im more worried about.
http://www.tdpri.com/forum/attachmen...headstocks-pdf gives you just about every headstock Fender ever (?) produced (these are Ed Hawley's drawings?). Print the tele to 100%, cut out and fit it on the strat head. You'll soon see if it'll work and what's needed. It is doable, just depends on how much effort you are prepared to invest. Just to see if it could be done I did this; http://www.agileguitarforum.com/showthread.php?tid=1436
va' sa' du? va' hete' du? |
If you square up the Strat neck heel, your screw holes will no longer be aligned with the body holes. A Strat neck can be put directly on a Telecaster. The main problem is a standard pickguard will show gaps in the corners.
. Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" I'm just not cool enough to be a Mac person. I'm a PC and Windows 7 was my idea. |
#10 (permalink) | |
I don't know which OP has, 'real' strat or aftermarket.
