gonna try to make a tele
so I was gonna try to make a tele out of recycled alluminum sheets about .5 inches thick but I dont know the specs of a tele. I know that it is about an inch and 3/4 thick but the length and width I cant find. Anyone want to give me an estimate or even someplace I could buy one of those card/particle board cut outs. I also could use some help on how to bind them together.
Am I reading you right, risingsun? You're talking about half-inch-thick aluminum? Like, stacked to make a solid billet? If so, this ought to be a fascinating build; I've seen hollow metal teles, but few solid aluminum ones.
Epoxy? You'd need a lot of it, and I'm sure there are better ways to bind aluminum, but my metallurgical knowledge is nil. I just know aluminum is hard to weld. There's a reason airplanes are all riveted together. Of course, if I misread your initial post, then I beg your pardon. Either way, the tdowns template is what you're after.
M Dixon Reading, MA |
industrial cyano adhesive will bond your sheets of alloy
if it were me i would be using 3 sheets , each 1/2 " (approx) thick , with the middle one hollowed out for the wiring , switch cavities etc |
thank you for your posts , and yes i should be more patient tuuur. I think im going to rivet them together and maybe find some way to corrode the metal just a little to give it an older look.
Aluminium is 2700kg/m3. Ebony is 1100. Light Ash is 450.
You'll need a lot of air in there - about 5 parts air to 1 part aluminium. Sounds cool - do a build thread!
You need to roll the dice to be in the game. |
i think im going to make it from a solid block of aluminum after researching prices i found that large thick pieces are cheaper than thinner smaller pieces so ill be getting a 1.25x19x19 ,im going to make the body less thick and also less heavy. when im finished i "hope" it comes out something like this but with a brass pickguard. http://www.specimenproducts.com/inst...m_guitar2.html
#12 (permalink) | |
Your project is fascinating, but listen to what Nick just said
about weight! Making the body 1.25" thick instead of 1.75 will reduce the weight by slightly less than 30%. If you're using material that's 5 times heavier than normal tele wood, then this means your body will be about 3 1/2 times heavier than a normal tele -- that's really heavy! Quote:
#13 (permalink) | |
Edit: I wonder if i use a magnetic metal for the body i could turn the body into a huge pickup Last edited by risingsun189; November 23rd, 2010 at 05:59 PM. |
