Old August 2nd, 2010, 11:36 PM   #1 (permalink)
strat neck on tele body?
so i was wondering. Will a strat neck work fine on a telecaster body? will everything intonate properly?
sixstringhook is offline   Reply With Quote
Old August 2nd, 2010, 11:41 PM   #2 (permalink)
drf64's Avatar
I had a USA strat neck on a MIM tele body. It fit fine width wise. I had to shim a little to get proper angle. Yes, intonation was fine. The problem was....it just didn't add anything to the sound. It's now on a Strat body and my dabbling in unnatural luthiery is ended.
dan
"Here dude, this one sounds like a fat lady stomping across your porch to bring you a fruitcake." -Jakedog
drf64 is online now   Reply With Quote
Old August 2nd, 2010, 11:52 PM   #3 (permalink)
sweet. im doing a custom build for a guy and he requested a strat neck be put on the guitar.
Old August 3rd, 2010, 12:40 AM   #4 (permalink)
Jack Wells's Avatar
Yes and yes.
Old August 3rd, 2010, 12:11 PM   #5 (permalink)
[IMG][/IMG]
GMAN715 is offline   Reply With Quote
Old August 4th, 2010, 03:52 AM   #6 (permalink)
mattdean4130's Avatar
You're taking the most beautiful part of the tele away!!!!!
mattdeanmusic.net
mattdean4130 is offline   Reply With Quote
Old August 4th, 2010, 05:12 AM   #7 (permalink)
Reverend D's Avatar
+1, but I guess the customer is always right (well even if they're wrong ). But I agree, I always thought the tele headstock was one of the nicest Fender even developed. Its just got such nice smooth lines, but hey its a personal preference I guess.
Regards,
Rev. D.
Reverend D is offline   Reply With Quote
Old August 4th, 2010, 06:13 AM   #8 (permalink)
spikypaddy's Avatar
Bit late to the party on this one, Clapton with Blind Faith:
And from Harmony Central, a guy had a Custom Shop replica of the above guitar built:
"If at first you don’t succeed, destroy all evidence that you tried." Josh Homme
spikypaddy is offline   Reply With Quote
Old August 4th, 2010, 06:34 AM   #9 (permalink)
jkingma's Avatar
Just for kicks...
Old August 4th, 2010, 08:32 AM   #10 (permalink)
KevinB's Avatar
Yes, it will fit and intonate correctly. But you should know that a Strat neck has a rounded heel while a Tele neck has a squared off one. Strat and Tele bodies are routed accordingly. What this means is that if you fit a Strat neck to a Tele body, there will be two small gaps at the neck pocket, but a standard Tele pickguard will cover them.
In reverse, a Tele neck won't fit on a Strat body without the neck pocket being routed to accommodate the square Tele heel.
KevinB is online now   Reply With Quote
Old August 4th, 2010, 08:41 AM   #11 (permalink)
so.... a strat neck could be " squared off " to fit a tele neck pocket with a nice snug fit without major intonation issues ? there should be enough for and aft movement at the bridge to compensate ?
julesyoung is offline   Reply With Quote
Old August 4th, 2010, 08:52 AM   #12 (permalink)
KevinB's Avatar
Yes, you could square one off to fit a Tele neck pocket, but any neck screw holes would then not quite line up. You'd probably have to fill and re-drill them, or you could I suppose move the body holes.
Would there be enough compensation at the bridge? Hmmmm....I'm guessing you'd lose about 1/8" at the neck, so yeah you "should" be able to compensate.
