#21 (permalink) | |
#22 (permalink) | |
#26 (permalink) | |
formerly "Big" Mike Simpson
http://www.stewmac.com/shop/Fretting...ng_Blocks.html |
#27 (permalink) | |
#28 (permalink) |
It takes exactly the time period between you starting and finishing
At some point people will point out to you that it's your job to learn how to build a guitar, not theirs - they'll say this in the nicest possible way, so don't be dissuaded by it - but perhaps take it upon yourself to establish a basic grounding in guitar construction and ask questions while you tackle the problems. This way, you'll find people will be much more free in giving their knowledge because it's worth giving knowledge to someone who has already started running with the ball, rather than asking 20 questions from the sidelines. Read the books. Read the threads. Get some wood. Ask a question when you come to an issue.
You need to roll the dice to be in the game. |
#29 (permalink) | |
#30 (permalink) |
Depending on your skills, just start and go from there. First you have to make good templates that is a good way to practise. You can make a perfect neck with a pocketknife if you are skilled if not, don't expect too much of it either way you gonna screw it up more than once.
![]() [EDIT:] Be sure you understand the whole proces of building a guitar like: How does a trussrod work. Where/why do I place my bridge etc. |
#31 (permalink) | |
#32 (permalink) | |
That should get your toes wet. You won't understand everything until you've made many necks, made many mistakes - there's no way around getting in to the trenches for a while to truly learn any craft. There is a lot to learn, and I think it's fair to warn that if you want to build your own necks for the sole purpose of saving money over having a custom one made, it's not likely to work out in your favor. If you're doing this because you want to learn how, then go to it and full steam ahead. In the long run though, if you want to get perfect results it's going to take a good investment in tools, time, and not all your early results are going to be ideal. If you want to make your own neck for the simple reason of getting one ideal end product however, it would probably be cheaper in the end just to save up and pay the $400-$600 that a custom finished neck would cost. Making guitars and parts is a great experience for a lot of hobbyists, but if money is a concern I'd say the advice often given to golfers applies here as well - Just take up shooting heroin. It's cheaper and less addictive. |
#34 (permalink) | |
#35 (permalink) |
And please excuse my question, but right now do you know how to do a complete set up on a guitar? If you don't then you might consider buying the cheapest eBay Chinese POS you can find and completely disassembling it, doing a fret level, crown and polish, nut adjustment, truss rod adjustment, reassembly and complete set up. If you can't do this you really have no business trying to make a body or neck from scratch.
#36 (permalink) |
Sounds good, right attitude, and I wish you the best. Books and advice from others is a good start here. Best thing from here on out if you're not in a rush is just to take it step by step.
From the bare lumber to the finished product, every step should reveal to you what particular tools or techniques you are lacking at that point, and you can put your procedure together piece by piece along the way. Many folks want to plan and invest in everything they need up front, but even the most well planned strategy rarely works out tangibly as you move along, and methods and tools will have to be adapted to for your situation along the way. Every time you get to a step that you can't satisfactorily complete, choices in tools and procedures can be decided and derived then, one step at a time. Don't invest in top of the line primo materials for your first build, as you should well anticipate the possibility of mistakes being made and those materials going to waste. Get some basic woods that will be suitable for a final product if it does work out, but don't spend top dollar on AAAA birdseye maple and brazilian rosewood until you've established some methods with some degree of predictability. Most importantly though, above anything else - Safety. Please take no offense, but I watched some of your other posts, and will only say that it is very important to understand how all tools are properly operated, especially when dealing with high speed cutters like routers, shapers, table saws, even a drill press. Learning to build guitars is certainly exciting, but it will do you little good if you don't have any fingers left to play them. Tools are dangerous, and need to be approached with a healthy respect, and thorough understanding of how they need to be operated. This must be your first priority in every single step of the building process. I would check around to see if there are any community colleges with a wood shop in your area. Many will offer courses which will not only offer some guidance and instruction, but also allow you access to many tools you may otherwise not have access to. Some even offer membership programs for personal use of the tool room, though they will often require you to find a sponsor (student/faculty/alumni) to get your membership. Good luck, take it slow, stay safe, and I think you'll do quite fine. |
#37 (permalink) | ||
#38 (permalink) | |
I certainly admire your enthusiasm and wish you good luck. |
#40 (permalink) | ||
One time I had the Bosch 1/4" spiral up bit that kept coming out of my router in the middle of cuts. I thought I was doing something wrong and that I was figuring it out. Finally, while routing a vintage style truss channel on a one-piece maple neck that bit came completely out and went straight through the neck. It would have gone through my foot/leg too if they were in the wrong place. I stopped what I was doing and I took that bit back that day - before I got tempted to use it again. It cut really smooth and clean, but just was not safe for me. |
