Wilde Pickups by Bill & Becky Lawrence Simmons Amp Repair Amplified Parts Acme Guitar Works GuitarSale.com Hahn Guitars Warmoth.com
Old March 11th, 2010, 03:12 PM   #1 (permalink)
Printing Terry Downs PDF
Hey Everybody-
I've found Terry Downs excellent PDF, but I'm having problem printing it (it either wants to compress it on one page, or just print the first page of what looks to be six or eight pages.)
Any quick tips to make this print out the entire document, at the correct size, on multiple pages?
Thanks, and sorry if I'm going over the same old ground.
Chris
ChristopherL is offline   Reply With Quote
Old March 11th, 2010, 03:20 PM   #2 (permalink)
adirondak5's Avatar
I believe if you use the snapshot tool and print it in quadrants with scaling set to none it will work , with the snapshot tool you select and mouse over the area you wish to print , then when you have all 4 pieces printed hold them over a light source so you can see through the top one to line up and tape together. Or copy the pdf to a thumb drive and go to Staples or Kinkos and have them print you up an actual size copy , about $3.00
HERB
"YOU SIR ARE NO GENTLEMAN" . "YEA , WELL I AIN'T NO DOOR KNOB EITHER!" Judge Smales & AL CZERVIK , Caddyshack
Old March 11th, 2010, 03:20 PM   #3 (permalink)
I would put the file on a cd, dvd or thumb drive and take it to Kinkos, have them print it out full size on one sheet, that's the best way to go unless you have access to a plotter or poster printer to print it out full size.
soulfixinman is offline   Reply With Quote
Old March 11th, 2010, 04:51 PM   #4 (permalink)
Stoked's Avatar
This might help you http://www.tdpri.com/forum/1809618-post4.html
Stoked is offline   Reply With Quote
Old March 11th, 2010, 07:00 PM   #5 (permalink)
Thanks Folks -
I think I may go the Kinko's route as I've also found a neck print I'd like to use.
Chris
Old March 11th, 2010, 07:15 PM   #6 (permalink)
neocaster's Avatar
I printed mine at Kinkos. If you have a plotter at work, that'll git er dun, too. Just turn off scaling when you print the PDF.
neocaster is offline   Reply With Quote
