| Home | Forum | Resources | T-Shirts & Etc | Music | Photos | Reviews | Classifieds | Register | FAQ | Search | Today's Posts | Mark Forums Read |
Les Pul with bolton Warmth neck
I am putting togeather a Les Paul with a bolt on Warmoth neck. My dilema is do I route the pocket with a 3.5 degree slope and sink the neck to the deck or should I do more like my epiphone special that the neck pockt is done like a strat and the neck is just a couple of mm off the deck to compensate for the height of the tunamatic bridge, or do a combo of both, with avery slight angle and leave the neck slightly off the deck?
Well what does the neck heel look like? If it is angled, you just need a flat mortise like a tele. If it is straight like a tele, then do about a 2 degree ramp for a LP jr/spec. or about a 4.5 degree ramp for a carved top. You can always put a little shim in there if you need to. I have a "real" 70's -80's gibson bolt- on neck here that is angled. In fact I can't recall a true gibson bolt on neck that was flat like a tele.
Gibson Invader, anyone?
![]() BTW, googling around for that image, I found a thread in another forum where someone was assembling a LP-copy with a bolt-on neck. He asked if he should glue the neck on, anyway |
Sonex, L6-S, S1, Marauder, Invader, Corvus, etc. I've owned all of these at one time or another except the invader. Some of these also had set neck versions with a higher price tag. Also I forgot the Kalamazoo guitars. They were bolt on too.
#11 (permalink) | |
The Marauders and the S1 sprang to mind immediately, as I played a Marauder in the late 70s. |
Only some of the L6S guitars had a bolt on. The majority were a set neck.
Which is why I said this above....:-) "Some of these also had set neck versions with a higher price tag." :-) |
