Wilde Pickups by Bill & Becky Lawrence Simmons Amp Repair Amplified Parts Acme Guitar Works GuitarSale.com Hahn Guitars Warmoth.com
Old March 11th, 2010, 07:18 AM   #1 (permalink)
tonyv77's Avatar
Tip for Template Makers
I don't know if this is a tip or not. However, I see everyone making templates using terry's PDF drawing ans simply gluing it onto a 3/4" MDF sheet and then cutting away. Then, like it happened to me, the paper rips. Why not glue it on, wait for the glue to dry and then hit it with some left over clear, varnish or whatever. Then when you are cutting around the paper will be nice and hard, and then when sanding comes along there's no worries. Also, I highly recommend using 1/4" MDF then transfering to 3/4" MDF as mentioned by jwells and others.
So, somebody tell me I'm stupid (I'm used to it).
tonyv77 is offline   Reply With Quote
Old March 11th, 2010, 09:46 AM   #2 (permalink)
DMichel123's Avatar
That's how I do it. Better than ripped paper....
DMichel123 is offline   Reply With Quote
Old March 11th, 2010, 10:24 AM   #3 (permalink)
Mojotron's Avatar
Ya - I use spray clear gloss poly over mine, then the same stuff on on the MDF sides when I get done cutting a master template.
Then I build with a copy of the master.
Old March 11th, 2010, 10:40 AM   #4 (permalink)
tuuur's Avatar
Thanks! Things like this make this forum worthwile...
http://www.myspace.com/tuuur
tuuur is offline   Reply With Quote
Old March 11th, 2010, 11:06 AM   #5 (permalink)
tonyv77's Avatar
I ain't so bad I guess
Nice to see some are already doing this
Hey tuuur, good to see some European input on this forum. Go metric system!
(Maybe someday I'll see your shop, I'm %100 3rd generation Dutch-Canadain and want to make a trip over.)
Old March 11th, 2010, 11:21 AM   #6 (permalink)
adirondak5's Avatar
Thats a good tip , last one I made I used a razor knife to trim to the line on the drawing so I wouldnt tear it when sanding to the line , spraying clear on it will eliminate that. Thanks !
HERB
"YOU SIR ARE NO GENTLEMAN" . "YEA , WELL I AIN'T NO DOOR KNOB EITHER!" Judge Smales & AL CZERVIK , Caddyshack
Old March 11th, 2010, 06:46 PM   #7 (permalink)
Thanks. Some times simple things escape me. Going to put this to work tomorrow. Taking a day off so I can work in the shop all day.
Sharp5 is offline   Reply With Quote
Old March 11th, 2010, 06:55 PM   #8 (permalink)
Ziggy's Avatar
I use minwax wood hardener to shore up the mdf. It soaks waaaayyy in to make it almost bulletproof.
I think I learned this from Ron Kirn.
Ziggy is offline   Reply With Quote
Old March 11th, 2010, 07:02 PM   #9 (permalink)
adirondak5's Avatar
Another good tip
HERB
Old March 11th, 2010, 07:43 PM   #10 (permalink)
Nick JD's Avatar
I cut the paper out to the line with scissors, tape it on in a few places and trace around it. Paper is thick enough to guide the pencil.
Tell me and I'll forget; show me and I may remember; involve me and I'll understand.
Nick JD is online now   Reply With Quote
Old March 11th, 2010, 08:41 PM   #11 (permalink)
tonyv77's Avatar
I'd do that but the plotter paper where I print my plans (at work) is to thin. Plus I would like to have holes and cavities laid out for me without worrying about the paper moving. Nick JD I think you're a bit over my skill level so you probably don't worry about these things like I do. I'm just a Engineering type guy who would like to work with his hands. I use all my technical skill I have to minimize the hands on learning curve.
Nice Idea about wood hardener. I should try that when I make the 3/4" "final" template.
Old March 11th, 2010, 10:09 PM   #12 (permalink)
Ziggy's Avatar
More tips with the minwax: Use a foam brush but don't drag; just tap. The mdf will soak up more.
I worry about wearing out holes when using them as guides for drilling. Short of inserting metal inserts, I use a syringe to squirt the minwax through the template. (small plastic bowl underneath) Keeps it from wearing out.
Old March 12th, 2010, 12:52 AM   #13 (permalink)
Hi guys
Plain ole' sanding sealer works real good.
bobbyblues is offline   Reply With Quote
Old March 12th, 2010, 01:53 AM   #14 (permalink)
Mojotron's Avatar
My neck template seemed to have shrunk 1/64" - any know of the best way to add 1/128th or 1/64" to each side?
Old March 12th, 2010, 09:24 AM   #15 (permalink)
Ziggy's Avatar
foil tape (like for HVAC)
Old March 12th, 2010, 10:05 AM   #16 (permalink)
mcurrie's Avatar
Hey Tonyv77, where abouts in NB are you? I'm in Fredericton.
mcurrie is offline   Reply With Quote
Old March 12th, 2010, 11:06 AM   #17 (permalink)
VENDOR
Ronkirn's Avatar
that's about .015.... or about the thickness of a good 'ol index card.... the paint will be thicker
n that when you're done.... don't sweat it... Leo didn't
Ron Kirn
"Freedom is not free..but the U.S. Marine Corps will pay most of your share".
"Tolerance is the virtue of a man without convictions." G.K. Chesterton
www.ronkirn.com
