Old January 25th, 2010, 11:25 PM   #1 (permalink)
gsoutherland's Avatar
Bookmatched walnut - a table saw re-sawing adventure
I had this piece of walnut sitting around for awhile that I didn't think had much future in anything guitar related. That is, until I got to wondering what it would look like bookmatched.
I took a photo of it and used PhotoShop to get an idea. I liked what I saw so off to the garage I went. I had seen some tips online before on how to re-saw with a table saw. I built a jig and a feather board and started making my cuts.
Here is a photo of what I started with:
Here it is on the table saw with the jig:
Unfortunately the wood was just a bit too wide for the blade to reach the middle, and thought I was stuck. I decided to go ahead and make all the cuts for both pieces and wound up with this:
Japanese pull saw to the rescue:
I was able to get my two pieces this way but they had humps/ridges down the middle. I glued them up and after taking them out of the clamps I hit them with a belt sander.
gsoutherland is offline   Reply With Quote
Old January 25th, 2010, 11:27 PM   #2 (permalink)
Here is what I ended up with:
I think it will make a nice top for my current Tele build.
Old January 26th, 2010, 12:41 AM   #3 (permalink)
Dababy's Avatar
Nice grain. I would build it with the neck on this side--> if it were me. I like the darker part and wouldn't want to hide it with pickups/pickguard.
Check out my website: Indie/ alt country/ praise & worship/ blues. Is that a genre? http://www.wix.com/JoelSkaggsMusic/dababyguitar
Dababy is offline   Reply With Quote
Old January 26th, 2010, 01:48 AM   #4 (permalink)
Targ's Avatar
You did a good job with what you had to work with...
but the kerf thickness on a table saw blade makes a good accurate book-match hard. With that nice piece of wood, I would have paid to have it done on a band saw if I didn't have one.
Still, nice job!
Targ is offline   Reply With Quote
Old January 26th, 2010, 08:43 AM   #5 (permalink)
Dababy, I do plan to build it with the grain oriented the way you say. I'm thinking of using a pickup ring and not having a pickguard on this one.
Targ, thanks for the compliment. I did not think of the thicker blade being the reason for the bookmatch not being as accurate as I hoped. That is good to keep in mind. With this piece I mostly just wanted to see if I could do it with the table saw.
It worked well enough for what I wanted this time, but if I was going to do it again I don't think I would go with the table saw. It was not easy, and my saw did seem like it was struggling a little. It is a low end Ryobi and does well enough for small jobs, but was not meant for this.
Old January 26th, 2010, 02:45 PM   #6 (permalink)
Targ's Avatar
Band saws present there own set of problems, mostly a wandering blade when dull. But if you have access to a wood shop that has the proper setup it is well worth it.
What you did was incredibly difficult to get right, so once again kudos on the herculean effort.
Old January 26th, 2010, 02:55 PM   #7 (permalink)
Mojotron's Avatar
Is there any power issue with the Ryobi 10-inch saw used this way - I'm wondering if doing this with hard maple would bog the rotation of the blade too much.
I would love to find a less inexpensive table saw to replace my old one that only cuts properly with thin stuff. Any ideas?
Old January 26th, 2010, 03:54 PM   #8 (permalink)
jkingma's Avatar
One of the tricks to cutting very thin pieces on a table saw is to make a zero clearance blade insert.
Old January 26th, 2010, 04:21 PM   #9 (permalink)
Mojotron, I think I would be a little hesitant to try this on hard maple. I felt like my saw was struggling a bit with this walnut. If you did try it I would say be sure to take a very small amount of wood with each pass. The problem with that though is the more passes you have to make, the more chances there are for things to shift. I think Targ's advice to seek out a good shop with a proper resawing setup would be best.
Old January 26th, 2010, 04:45 PM   #10 (permalink)
I make alot of my tops and even fingerboards this way..On the table saw. It does not make pefect book match due to a bit more wood removed, but a wondering blade on a bandsaw could be worse. At least the cuts are straight.
Even with my fingerboards (which I could cut through all the way) I leave about 1/8" connecting it. I then run them down my bandsaw to cut in half. I just think its safer than having the blade raised and exposed that much.
Anyway, I have several archtops made from walnut. The backs were cut exactly as you have done..minus the fancy jigs.
J
joe desperado is offline   Reply With Quote
Old January 26th, 2010, 04:57 PM   #11 (permalink)
tweeet's Avatar
Bear with me....I've got two planks of ash 20" long x 8" wide and 2 1/4" thick.Could I use a table saw to cut through one side,lengthways,then flip it over and do the other side and use a handsaw to cut the remander middle piece.In theory I would then have,depending on the thickness of cut of course, two pieces left.......one say 1 1/2" thick and the other 1/2" thick (eg.minus thickness of saw blade).Otherwise the only way for me to get down to 1 1/2" or 1 3/4" on these planks is to use my thickness planer and that's a hell of a lot of wood to get rid of using that.What d'ya think?
Thanks
On closer examination of the above pics.....I don't see why not...unless someone says otherwisw!
tweeet is offline   Reply With Quote
Old January 26th, 2010, 05:04 PM   #12 (permalink)
axmaker's Avatar
heck yeah it will, that looks great!
Old January 26th, 2010, 05:07 PM   #13 (permalink)
Mojotron's Avatar
What I have been doing is to take my skill saw and doing the same thing - only with the wood clamped down to a bench and running the saw over the top of it. The skillsaw only works for 2-4" boards when making fretboards - I find a piece with nice grain, cut it out rough, then plane it out flat. I've been thinking of getting a good table saw for this, but I'm not sure which to get - I'm looking at a Ridgid, but perhaps a cheaper one would work?
Old January 26th, 2010, 10:57 PM   #14 (permalink)
Tweet, what you're describing is pretty much what I did. Just be careful, I saw some pretty gnarly pics of table saw re-sawing gone bad (severed fingers) but I guess that pretty much goes for any woodworking, right? The thing I saw most repeated was that the board needs to be as straight and flat as possible. A twist in the board could cause some nasty kickback. I think if I had a thickness planer though, I would just use that. I've used my router to do thickness planing and taking off 1/2" of wood really didn't take that long. I use a 1 1/4" wide mortising bit for that.
Axmaker, thanks. I have it gluing up right now and will be updating my build thread with pics soon.
Mojotron, it might work just fine, but if I were planning on doing this with a table saw on a regular basis I think I'd be looking for a beefier saw.
Old January 27th, 2010, 03:37 AM   #15 (permalink)
tweeet's Avatar
[QUOTE=gsoutherland;2271514]Tweet, what you're describing is pretty much what I did. Just be careful, I saw some pretty gnarly pics of table saw re-sawing gone bad (severed fingers) but I guess that pretty much goes for any woodworking, right? The thing I saw most repeated was that the board needs to be as straight and flat as possible. A twist in the board could cause some nasty kickback. QUOTE]
Thanks GSouth...I'll ponder over it.If I do go ahead I'll have to take it to the timber merchants as I haven't a table saw anyway.....the wife won't be too happy if I buy another piece of machinary!
Old January 27th, 2010, 05:07 PM   #16 (permalink)
old_picker's Avatar
just a word of caution resawing with a table saw
The TS is the most vicious tool in the woodwork shop
remember the blade is fully extended and completely buried in the stock
it takes only the slightest deviation in any direction to jam one of the saw teeth
the full energy of the motor is then engaged to your heavy chunk of hardwood, hurling it towards your head at 60 miles an hour
i have had a small TS [2hp] grab a piece of 1/4" mdf around 12" square -
it flew off the bench and hit me in the upper stomach - it tore out a chunk of skin and winded me pretty badly - it was over before i knew what happened - it was instantaneous - my attention went off the job - bang - i was on the floor
doesnt take much imagination to picture a 9lb chunk of walnut colliding with your head at this kind of speed
dont want to freak anyone out but in my mind the bandsaw is a much friendlier way to resaw - even if the blade wanders a little
properly setup with a decent blade and the right type of fence its very easy
ray
old_picker is offline   Reply With Quote
Old January 27th, 2010, 05:45 PM   #17 (permalink)
SacDAve's Avatar
I just did a top the same way instead of using the band saw. Main reason the wood for the top was about $90 and I could only get one top from it. What I do is depending on the wood type I just make a lot of passes average about 1" I also use a thin kerf blade. I just go against the fence and use a spring board against the wood to hold to the fence. I finished mine off with the bandsaw. Like everyone else is saying just be carful. I’m using a 3HP cabinet saw I’ve been put on the ground a couple times. One thing to remember if the blade gets to hot it will literally start to distort and then you’re in for some fun. But it looks everything came out nice.
SacDAve is offline   Reply With Quote
Old January 27th, 2010, 06:04 PM   #18 (permalink)
robt57's Avatar
Nice job, kerf make a lot of sawdust, don't it...
Been there, done that as far splitting walnut too.
Minimum estimated 70 year reclaimed, very happy to see what was in te middle of this reclaimed barn rough cut plank. Full 5/4 x 8 rough cut when I started. My sis got it from the owners of the barn, well their parent had owned it.
A Twin always will cut it... but I don't recommend it for everybody. It's like a big dog, you have to take responsibility for it. Not to mention... be prepared to lift it.
BTW, how $good$ a guitar is, is no indicator of how badly it can be played!
Old January 27th, 2010, 10:42 PM   #19 (permalink)
That's a nice lookin' hunk of wood there, robt57
Old January 27th, 2010, 10:46 PM   #20 (permalink)
robt57's Avatar
5/16" Walnut drop top on clear 1/4 sawn cedar back.
