Wilde Pickups by Bill & Becky Lawrence Simmons Amp Repair Amplified Parts Acme Guitar Works GuitarSale.com Hahn Guitars Warmoth.com
Old December 5th, 2009, 05:07 PM   #1 (permalink)
micpoc's Avatar
Recessed straplocks?
Has anyone here ever attempted a recessed straplock as seen on this Alembic?
It seems like implementing this should be pretty straightforward, but if anyone has an tips, I'd appreciate them. I'll be doing this on a guitar with a fairly heavy finish, and chipping that finish is my biggest concern.
"Everybody should be able to make some music - that's the cosmic dance!" - Maude
micpoc is offline   Reply With Quote
Old December 5th, 2009, 05:19 PM   #2 (permalink)
voided3's Avatar
Those are the old style Dunlop ones, right? I'd imagine if you use a properly sized and sharpened drill bit with the area to be drilled taped over with painter's/masking tape, it would go alright. Just go slow.
www.youtube.com/voided3
voided3 is offline   Reply With Quote
Old December 5th, 2009, 09:29 PM   #3 (permalink)
VENDOR
mellecaster's Avatar
Here's a Screen capture from an older post about those...might be of some Help ?
Contact Info
mellecaster is online now   Reply With Quote
Old December 5th, 2009, 09:44 PM   #4 (permalink)
micpoc's Avatar
Yes, they are the Dunlop style. Right where the button would contact the body it flares out a bit, and I though it might be a good idea to file that down, though maybe that's just more work than is necessary.
One thing I was curious about was whether or not I should use some sort of wood putty to fill the remainder of the space left by the drilled cavity.
Old December 5th, 2009, 10:02 PM   #5 (permalink)
twangmastermike's Avatar
hey micpoc;
i have recessed the strap locks on all of the guitars i have built so far. in that instance, i do all of my machining before the finish.
when i recess the locks for someone else, on an already finished guitar, i start with a drill bit about 1/2 the size of the finished hole and work up to the final size. it takes a couple of extra minutes, but the chance of chipping the finish is much less.
i undersize the hole slightly, so i get a nice tight "push fit".
try to drill the holes only as deep as need be. if they are drilled too deep, a piece of dowel glued in the bottom of the hole will work better than wood filler.
this really cleans up the appearance of a guitar.
make sure all your bits are SHARP.
"A man is accepted into church for what he believes--and turned out for what he knows."
- Mark Twain
twangmastermike is offline   Reply With Quote
Old December 6th, 2009, 07:46 PM   #6 (permalink)
micpoc's Avatar
Thanks for the assists, guys. The strap locks I have don't look exactly like those posted by Mellecaster; like I said, they flare out a bit on the body end, like here:
Perhaps my idea of filing the buttons down would be a good move after all?
Old December 7th, 2009, 03:02 AM   #7 (permalink)
steadyriot's Avatar
That would indeed be a good move.
Originally Posted by Controller View Post
Who needs to text while driving? You can play your Tele!
steadyriot is offline   Reply With Quote
Old December 7th, 2009, 03:16 AM   #8 (permalink)
brewwagon's Avatar
just buy these buttons
http://www.jimdunlop.com/index.php?p...ts/accessories
bw
Music an art form whose medium is sound.
brewwagon is offline   Reply With Quote
Old December 7th, 2009, 12:01 PM   #9 (permalink)
Ditto on the above if you want to do the full recess.
Hamer uses the larger Dunlop buttons above, and recesses them a bit, but not completely. They do a small rout and add a rubber gasket as a "shock absorber" in there. It gives it a slightly lower profile than if it was just surface mounted, but also gives you the bigger button, which is easier to grab on to when changing straps.
cmatthes is offline   Reply With Quote
