Drilling the string-through holes. Questions.
I'm in the process of modifying my drill press so it will have a deep enough throat to drill the string through holes.
My question is once I'm ready to drill, how do I ensure the holes are in a straight line? I've seen the tips on drilling half way and using the pin once the body is flipped so you can match the holes when drilling the rest of the way, but how do you ensure they're in a straight line when you do the initial drilling? I could easily see getting off a bit when moving from one hole to the next. I've tried to practice using an awl along with my blueprint to punch a starter hole for the drill bit, but that is done by hand and is easy to get off center a little. How do you guys do it? |
#3 (permalink) | |
I just did this last night and I will be adding some photos and info to THIS THREAD so check it in a while and all will be revealed...
Creator of Fine Sawdust and Expensive Kindling. |
more clickin' goodness:
http://www.tdpri.com/forum/tele-tech...ugh-holes.html |
| Drilling string through holes in a Tele bass? | mudslinger | The BASS Place | 5 | August 30th, 2008 06:03 PM |
| Drilling string ferrule holes | Brick | Tele-Tech | 35 | March 11th, 2008 09:35 PM |
| Drilling holes in a chassis | TelZilla | Amp Central Station | 8 | January 2nd, 2008 01:45 PM |
| drilling pickguard holes | TelZilla | Telecaster Discussion Forum | 10 | February 2nd, 2007 02:03 PM |
| Drilling Bridge Mount Holes and Pickguard holes???? | jjh37854 | Tele-Tech | 1 | November 19th, 2005 02:39 AM |
