Neck radiusing router jig
In the next days (december at all) I'll have to radius 6 guitar and 2 bass necks, so today I started the build of a radiusing jig for the router.
I opted for the rails one, I think it can be easier and cheaper to build ![]() The four bolt will allow to change height of the rails to accomodate various situations. The aluminum rails are 1" x 39", the base is 6/8" MDF 7" x 39", the router base is 3/8" MDF. Started with MDF base, cutted it to 7" width ![]() I made the first hole on the rails in this way to be perfectly square ![]() I used the router to cut the arcs, it came out well, but mdf arcs are too soft and tomorrow I'll make others with multi-ply or solid wood ![]() Suggestions are welcome! Ciao Mauro |
Nice Mauro! I think you can laminate some thin strips of Nylon or equivalent to the MDF as a bearing surface and be fine. Thin Brass is an option as well, using some thin film spray lube on the rails such as furniture polish (Pledge here in the States) will help it glide. Good Job!
On what do you bias your opinion? |
That'll work. It will also do compound radii if you want by changing the distance between the rails from one end to the other. Closer together = tighter radius.
Wes McMillian Santo, TX |
#6 (permalink) | |
Thank you Mauro |
#7 (permalink) | |
Ciao Mauro |
I'm not convinced of this. The radius is determined by the piece the router is stuck to. If that bit is made for a 9 inch radius, it won't matter what distance the rails are apart, it will still make a 9 inch radius.
Seargent Throat? Yes? Make a note. Right, make a note. Yes. Right. |
I think moving the rails together won't give you a different radius, it will just drop the bit in relation to the top of the neck blank. You're not changing the radius of the circle; you are, however, changing the center point.
I think this is what you're looking for.
http://www.woodworkingtips.com/etips/2004/10/08/sn/ Just remember that when making a circle you're measuring to the inside of the bit, when using the radius sections measure to the outside of the bit. |
#14 (permalink) | |
I measured the outside (respect to the center of the 1/4" pivot point) of the router bit, then made some passes on a scrap, and it came out perfect. In practice I summed the 12" radius + the protruding of the bit (2/8") + the width of the router bit. You just have to extra-tighten nuts and bolts, screw and so on... and take care for the underside of the cut (the first time I cut the loudspeaker hole for my combo I routed also a part of the table I was working over). Mauro |
#15 (permalink) | |
Don't know about the center point, if the rails are symmetric it should remain the same. However, on the jig I'm making, the distance between the nuts in relation to the radius to obtain (obviously with the proper arcs) is the following 9.5" ---> 4" 1/4 12" ---> 4" 3/4 16" ---> 5" 2/5 Ciao Mauro |
#16 (permalink) |
The center point I'm referring to is the center point of the circle from which you cut your arcs. This is fixed when you cut those arcs out. As such, if you move the arc up and down, you are effectively moving the center point of the radius up and down.
The bit is going to essentially trace the radius of the arcs that you cut out. No amount of changing the distance of the rails will change that. As such, the radius of the top of the neck blank will be the same, but you will be changing the height of the bit as you go down the length of the fretboard. In order to do a compound radius on this kind of jig, you would have to modify the arcs as you progress. This won't come easy -- there are other compound radius jigs that would be a much simpler task than modifying this to do compound radius. |
#17 (permalink) |
Here's one I made, if you flip it it does radius sanding blocks.
DSC00443.jpg |
#18 (permalink) |
Hi maumari.
Have you taken a look at Scatter Lee solution. Some of his things are brilliant in its simplicity. Hear are the page I’m thinking of Some of my jigs and templates Take a look on page 3 and it may help you along. Hans R |
#19 (permalink) |
CORRECTION! PAY NO ATTENTION TO THE IDIOT BEHIND THE CURTAIN!
I glanced at this and posted in haste. The guys are right, adjusting the rails on this jig will not result in a compound. Geeze......it's not like I've never built a compound radius jig before. Sorry about that....
#20 (permalink) | |
Thanks Mauro |
#21 (permalink) | |
Mauro |
#22 (permalink) | |
There's always something to learn somewhere... Mauro |
#23 (permalink) | |
#25 (permalink) | |
#26 (permalink) |
I made the final router plate and arcs from multi-ply (respectively 3/8" and 6/8" thick), because the prior MDF ones where too weak.
![]() Made a try on some pine with a simple 1/2" router bit (not a planing one) ![]() and I have to say that it really works. ![]() I found out that it works better by moving the router vertically along the "fretboard" and not side by side. Moreover, I will make arcs for 7,5" radius that will fit vintage teles and a fretless semi-hollow piezo bass ("inspired by" Rob Allen ones). Now I'm gonna experiment around the carving of the back of a neck with a rounding bit. Any suggestion? Ciao Mauro |
#28 (permalink) |
Today I made a try with a blank of hard "whatsoever" wood (I cut some fret slots too)
![]() Except for some chops (I'm the master of chops) along the border, due (I think) to the wood itself ![]() it worked very well ![]() Then I radiused the first "official" maple fretboard (the one for secret project codenamed BB) ![]() I adjusted the height of the rails to the "wood sandwich" with the fretboard on the top by adding 1 washer (1/16" thickness) for each nut. It came out "almost perfect" in about 80 seconds. Remember, to have a good result you must move the router vertically; I start with a pass on the centerline, then proceed each pass following the border of the previous cut with the center of the router, slowly without pressing, it flows by itself. Very satisfied! Mauro |
| what's a neck pocket router hump? | mlove3 | Telecaster Discussion Forum | 6 | September 19th, 2009 01:18 PM |
| Neck carving with table router | matthew bryan | Tele Home Depot | 12 | July 25th, 2009 08:02 PM |
| Fret markers before or after radiusing | shoretyus | Tele-Tech | 4 | March 25th, 2008 08:22 PM |
| Router Help!! | boneyguy | Tele-Tech | 35 | December 2nd, 2007 09:22 PM |
| Thoughts on re-radiusing fingerboard during refret | blauserk | Telecaster Discussion Forum | 3 | February 19th, 2004 12:15 PM |
