Old November 29th, 2009, 12:38 AM   #1 (permalink)
HELP!!!! My pots aren't working!!
Hi everybody. I'm new to this site, so any help will be GREATLY appreciated.
I have changed bridge pickup on 69 thinline reissue from stock to the custom shop hand wound '50's model single coil. Also changed the stock cap to a .047 poly cap. Re-soldered everything back in its original place and fired it up. THE VOLUME POT DOESN'T TURN COMPLETELY OFF AND THE TONE POT DOES THE SAME.
Why is this happening?
Please help! I've wired it exactly the same as it was before, and even re-soldered connections to ensure I didn't have a cold joint.
Any help is great.
Thanks,
Todd
hottoddytele is offline   Reply With Quote
Old November 29th, 2009, 01:21 AM   #2 (permalink)
CptRyg's Avatar
I've only done one before and had an issue where my tone didn't do anything. I resoldered the capacitor but before I did that I scratched up the surface of the pot where the capacitor connected. I figured there was some kind of varnish on the metal. It worked. I'm no electrician so I may be off base. Just a thought from my limited experience.
CptRyg is offline   Reply With Quote
Old November 29th, 2009, 01:49 AM   #3 (permalink)
If your volume doesn't go to zero at full CCW, then your ground connections are suspect.
cc9cii is offline   Reply With Quote
250K pots vs 500K pots JPark The BASS Place 4 January 28th, 2009 04:05 AM
Linear Pots vs. Audio Pots (Les Paul question) Pesty Tele-Tech 10 January 9th, 2008 09:52 AM
Converting 500K pots to 250K pots Donovan_45 Tele-Tech 7 September 18th, 2006 03:08 PM
Large Pots vs Miniature Pots. jwells393 Telecaster Discussion Forum 1 August 3rd, 2004 01:50 PM
250K pots v. 500k pots 53 Esquire Telecaster Discussion Forum 8 November 26th, 2003 08:59 PM
