Shaping Fingerboard Blank
I am making my first neck for my next Tele. I have the neck template and a piece of curly maple with a maple fingerboard blank. My question is: What is the best way to shape the fingerboard? Should I shape the neck first then glue fingerboard blank to neck and shape it using a router and the neck as the template guide?...or shape the blank before gluing to the neck using my neck template as a guide?? What is the best way that will least likely cause tear-out from the router?
Thanks Keith |
I've only done two necks in my life, and they're not complete, BUT I've had success using the first method you mention: gluing the fretboard to the neck and using the neck as a template to shape the fretboard.
The best way to avoid router tearout is to use a sander to get the fretboard as close as you can to the neck, before routing, so that the load on the router is as little as possible. I use a simple sanding drum that mounts in my drill press.
| Shaping Body Edges | McFly | Tele Home Depot | 7 | May 10th, 2009 08:29 PM |
| Neck Shaping | Bill Scheltema | Telecaster Discussion Forum | 13 | August 19th, 2008 01:39 PM |
| Update on shaping the neck | hmx1 | Stratocaster Discussion Forum | 0 | February 11th, 2006 11:13 PM |
| G&L Neck Shaping............. | jwells393 | Telecaster Discussion Forum | 15 | February 5th, 2006 06:46 PM |
| Headstock shaping | GuitarJonz | Telecaster Discussion Forum | 0 | November 12th, 2003 11:17 AM |
