Old November 28th, 2009, 05:35 PM   #1 (permalink)
mudbean's Avatar
Mud's 1st Finish & Build Complete: Ol' Piney #1
YAY!! At long last (O.K., so I haven't been exactly slaving away at this thing) I have a guitar! A Blackguard!! Not a hunk of pine, not a WIP, not a horrid mess, but a guitar! And she's a FAT BLONDE, to boot! All 1-7/8 inches of 'er (yep, I said fat!) ... I've always had a thing for fat blondes ... but I digress ... here she is:
I like the black velvet photo dealio, but I'm having a devil of a time getting a good (read: true-to-life) color balance ... this one's more accurate:
O.K., specs:
Body - Pine, two piece, rough cut, purch from TDPRI member guitarbuilder Marty.
Neck - AllParts TMO-FAT, med jumbo frets, TUSQ nut, purch from Mark at mjw customs (highly recommended - Mark does a very nice job of dressing the fret ends before shipping to you, and has great prices).
Pickups - Don Mare Blackguards (hee hee!)
Bridge - Wilkinson 3 saddle, brass, compensated
Control Plate - Nice thick plate from Guitar Fetish, matches PG thickness
Electronics - Stew Mac Tele wiring kit, Electrosocket jack cup
Tuners - Stew Mac vintage split post style
Knobs - geniune Fender Domes (hey, I wanted something "real"!)
I had no idea how cool it would feel to hold & play a guitar I made myself! Suddenly, all my store-bought Teles don't seem so special anymore ... hmmm ...
mud
MudBean Music
Nekkid Bart: "This is the worst day of my life."
Laffing Homer: "Worst day SO FAR!!"
mudbean is offline   Reply With Quote
Old November 28th, 2009, 05:37 PM   #2 (permalink)
jkingma's Avatar
Wow, looks great.
jkingma is online now   Reply With Quote
Old November 28th, 2009, 05:38 PM   #3 (permalink)
Moderator
getbent's Avatar
nice work mudman!
Leadership isn't just reaching for the brass ring and holding on. Leadership is reaching for the brass ring and using it to pull yourself over so that you can help others do the same thing...
Old November 28th, 2009, 05:48 PM   #4 (permalink)
mudbean's Avatar
A bit of the saga ...
Raw pine body from Marty (Marty made this body just fine, BTW - the fat part came from me, my sprayer and a helluva lotta bug shells!):
I did the edge radiusing by hand (I worked it hard, wanted a soft edge) with 150 grit sandpaper, then smoothed to 320:
The DIY section here at TDPRI has been my inspiration, education, and exhasperation ... I opted to try shellac as a base coat under my planned Butterscotch Blonde nitro ... my first forays into shellac application were rocky, at best:
Sanding block to the rescue:
mud
MudBean Music
Old November 28th, 2009, 06:21 PM   #5 (permalink)
mudbean's Avatar
On the spraying stand, after several coats of ReRanch Butterscotch Blonde nitro:
The body did not have the jack hole drilled (I forgive you, my friend!) ... I needed to get a drillpress anyway ... I set this up referring to Jack's photo, worked great (yes, I know, I painted it before I drilled the hole ... ssshhhh):
Then came many coats of Deft Gloss Nitro Lacquer, and waiting, and sanding, and spraying, and waiting ... here, wetsanded to 1200 grit:
Lastly, on to the buff ... figured I'd try it by hand - my shoulders lasted approx 10 minutes (ouch!) before I ran to the auto parts store for an electric buffer - best 20 bux I ever spent. It's amazing how the finish changes through the process - after wetsanding to 800,then 1200 grit, the matte surface looks soft, even though it's not ... as you progress through the rubbing compound, then polishing compound, it "hardens" in appearance as it takes on a shine - but it's not until the magic last step: Meguiar's Scratch-X2.0, that the shine explodes. Here, we still see some fine scratches in the surface - subsequent Meguiar's treatments remove these as well:
mud
MudBean Music
Old November 28th, 2009, 06:39 PM   #6 (permalink)
lespauljr's Avatar
A fine job anybody would be proud of.
lespauljr is offline   Reply With Quote
Old November 28th, 2009, 06:54 PM   #7 (permalink)
pchilson's Avatar
You've done some fine work there mudbean, be proud. Will you be doing it again?
pchilson is offline   Reply With Quote
Old November 28th, 2009, 07:38 PM   #8 (permalink)
woodman's Avatar
nice piece o' work, mud — i wondered where you'd been!
Old November 28th, 2009, 08:25 PM   #9 (permalink)
edgemarc's Avatar
Very Very Nice! Excellent job!
On what do you bias your opinion?
edgemarc is offline   Reply With Quote
Old November 28th, 2009, 08:48 PM   #10 (permalink)
Jack Hole+10 dollars....:-). Nice work by the way!
Old November 28th, 2009, 10:34 PM   #11 (permalink)
mudbean's Avatar
Hey, Marty! Gotcha - I'll keep that in mind for next time ... I do believe I turned blue, holding my breath throughout the drilling procedure!
Many thanks, all - yes, this is my first try, more now hanging to cure (a couple ready for wetsanding!).
I gotta tell ya, I'm hooked at the first bite of the Partscaster bug ... I may just sell my MIM Stds ... go figure ...
Also, weight of finished body (before metal) was 4.45 lbs. Total assembled weight of guitar is 7.42 lbs. She may be chunky, but she's light on her feet!
Here are a couple more looks. Checkout my homemade decal - also checkout where Mudthespazz drilled a pilot hole right through the headstock (yup, on the last one ... grrrr). No worries, easy repair, and the headstock is not totally done (I couldn't wait, slapped 'er together to show the family for Turkey Day):
mud
MudBean Music
Old November 28th, 2009, 11:24 PM   #12 (permalink)
gagidlof's Avatar
That came out great, I'm building a pinecaster blackguard with a goal to come out just like yours only difference I'm going with the rosewood fretboard.
That really looks nice way to go, that is something to be proud of. I hope mine looks as nice when I'm done.
gagidlof is offline   Reply With Quote
Old November 29th, 2009, 12:16 AM   #13 (permalink)
JCBurke59's Avatar
Nice, nice job.
My 'Blackguard' partscaster is northern ash and a little heavy - 8.5lbs, or so. I'd love to do one in pine one of these days.
It is addictive, isn't it?
Joe
all partscasters, all the time...
JCBurke59 is offline   Reply With Quote
Old November 29th, 2009, 01:34 AM   #14 (permalink)
Zillinois's Avatar
Nice work! At some point I'm going to have to commission someone here to build me something nice!
Zillinois is offline   Reply With Quote
Old November 29th, 2009, 12:48 PM   #15 (permalink)
FirstBassman's Avatar
Wow, congrats! Very sweet looking.
And I'm sure she sounds great. Enjoy.
FirstBassman is offline   Reply With Quote
Old December 4th, 2009, 01:45 AM   #16 (permalink)
mudbean's Avatar
Thanks, guys!
Quick follow-up note: I had a static problem with my pickguard - a little strip of aluminum foil under the PG, secured by the nearest Control Panel screw, cleared it right up. TDPRI saves the day yet again!
mud
MudBean Music
Old December 4th, 2009, 04:49 AM   #17 (permalink)
very very nice guitar mate.
52Tele_lover is offline   Reply With Quote
Tex-Caster First Complete Build msuguitarman Tele Home Depot 20 July 2nd, 2009 03:51 PM
2nd Build Complete ctelep Tele Home Depot 11 April 14th, 2009 01:17 AM
Esquire build/Piney#2 gets some tinted Nitro, robt57 Tele-Tech 23 July 26th, 2008 05:00 PM
First Amp Build Complete TelZilla Amp Central Station 8 December 26th, 2007 02:55 PM
first build complete!! here she is trev flint Telecaster Discussion Forum 15 June 15th, 2007 01:46 PM
