Old November 21st, 2009, 03:29 PM   #1 (permalink)
Puresoundguitar's Avatar
Adjustable string spacing Tremolo??
Hi there,
Anyone knows a tremolo, or saddles with adusjtable string spacing?
I kind of made a mistake in a neck (too narrow) and now the only way of correcting it, will be reducing the string spacing at the bridge.
Any other suggestions?
Thanks
Puresoundguitar is offline   Reply With Quote
Old November 21st, 2009, 09:06 PM   #2 (permalink)
I've never seen saddles that is adjustable.
In general, Fender saddle pitch is 11.2mm or 11.3mm, some aftermarket bridge such as Gotoh is 10.8mm.
But you can find some bridge that is 10.5mm saddle pitch.
zero-sss is offline   Reply With Quote
Old November 21st, 2009, 09:17 PM   #3 (permalink)
jkingma's Avatar
I've never seen any bridge that will do what you want.
Sorry.
jkingma is online now   Reply With Quote
Old November 21st, 2009, 09:29 PM   #4 (permalink)
Nick JD's Avatar
Schaller make a non-trem with adjustable string spacing.
Old November 22nd, 2009, 03:13 AM   #5 (permalink)
Check out http://www.kahlerusa.com/home.html
My white hairs had you fooled, didn't they, son?
Yes, Sir!
Ha! Drive on!!!
Westerly Sunn is offline   Reply With Quote
From 2 7/32 to 2 1/16 string spacing with 2 7/32 bolt spacing, HELP! ShortBuSX Stratocaster Discussion Forum 16 January 8th, 2009 12:13 PM
Non-adjustable poles & wound 3rd string Ron C Just Pickups 4 August 14th, 2008 08:05 AM
String spacing at nut Rogera Telecaster Discussion Forum 4 August 7th, 2008 04:08 PM
hardtail strat bridge - string spacing & string hole body routing question appar111 Tele-Tech 0 January 4th, 2008 01:02 PM
String Spacing? supa_scoopa Tele-Tech 1 March 14th, 2004 04:36 AM
