Old November 20th, 2009, 01:56 PM   #1 (permalink)
I need help with color
Can someone tell me how to get butterscotch blonde withut using reranch cause i dont have that possibility?Thanx!!!
danyboy is offline   Reply With Quote
Old November 20th, 2009, 05:11 PM   #2 (permalink)
kman900's Avatar
Europe is big . . where are u located? In the UK you can get some from http://www.mohawk-finishing.co.uk/.
Using an apostrophe for plural sucks
kman900 is online now   Reply With Quote
Old November 20th, 2009, 07:40 PM   #3 (permalink)
I am from Croatia
Old November 20th, 2009, 10:32 PM   #4 (permalink)
hackworth1's Avatar
Get some different tones of hair dye or clothing dye and try it on scrap wood.
Old November 21st, 2009, 05:17 AM   #5 (permalink)
Shepherd's Avatar
http://www.mixol.de/front_content.php?idcat=91&lang=
Old November 21st, 2009, 08:57 AM   #6 (permalink)
Originally Posted by danyboy View Post
I am from Croatia
M-Color Zavrtnica, Zagreb. Lacquer name: "pepsi cola". Nitro.
kifla is offline   Reply With Quote
Old November 26th, 2009, 05:51 PM   #7 (permalink)
Hvala.Jeli to ta boja ili se mora mješati sa nečim?
Old November 28th, 2009, 01:43 PM   #8 (permalink)
jrich99's Avatar
jrich99 is offline   Reply With Quote
Old November 28th, 2009, 01:59 PM   #9 (permalink)
neocaster's Avatar
Google says "ate to the color or to be confuse with something?"
neocaster is offline   Reply With Quote
Old November 28th, 2009, 08:29 PM   #10 (permalink)
edgemarc's Avatar
I think it means "Coke or Pepsi"?
On what do you bias your opinion?
edgemarc is offline   Reply With Quote
Old November 29th, 2009, 12:36 PM   #11 (permalink)
try oil based brush on paint. Can mix yellow ochre and a little white, then add 50/50 linseed or walnut oil and turpentine or mineral spirits to make it a heavy cream consistency and roll it on with a high density foam roller. The paint will self level. Still have to wet sand from 400 to 1000 grit and then rubbing compound to a high gloss. Then again you can likely go to the hardware store and have some oil based paint mixed up for you. Thin it down to a creamy and roll it on. It will take about three coats sanding between each.
Anwar is offline   Reply With Quote
On which Telecaster(s) does the headstock color match the body color? Califiddler Telecaster Discussion Forum 8 March 23rd, 2009 11:04 PM
dupli-color color shift kit spray cans TELE_BLUES Finely Finished 6 January 25th, 2009 11:41 PM
Possible to change color from wine color to butterscotch? Tsuekasa Telecaster Discussion Forum 7 June 5th, 2008 09:53 PM
help with color?? missing_dave Stratocaster Discussion Forum 0 March 13th, 2006 09:41 PM
Which color? Kevin Telecaster Discussion Forum 61 May 6th, 2004 03:45 PM
