Old November 16th, 2009, 09:55 AM   #1 (permalink)
What pickguard with tdowns blueprint?
Is there a specific pickguard I should look for to use with a body I make from the tdowns tele blueprint? '52, '62, USA, does it matter?
gsoutherland is offline   Reply With Quote
Old November 16th, 2009, 01:10 PM   #2 (permalink)
Not as far as outline goes. The original shaped guards all have the same outline. What occasionally differs is the hole placement, but you'll want to wait until you have both the guard and control plate placed before you start drilling, so no... no difference.
Casual_Reader is offline   Reply With Quote
Old November 16th, 2009, 01:22 PM   #3 (permalink)
i found that an standard tele pickguard will work great. some imported pickguards are built a little different shape
Guitartom_ca is offline   Reply With Quote
Old November 16th, 2009, 01:50 PM   #4 (permalink)
preeb's Avatar
Why not cut the guard yourself?
PM if you need a trace.
preeb is offline   Reply With Quote
Old November 16th, 2009, 03:49 PM   #5 (permalink)
Preeb, IM sent. I might do that eventually, but I was thinking of just grabbing one quickly to check my templates. I cut them out this weekend and when I placed the plan over my templates I noticed I somehow got the control plate cavity off a bit. I wanted to hold a pick guard up to see if I'm still ok or if I need to re-cut it.
Old November 16th, 2009, 04:01 PM   #6 (permalink)
preeb's Avatar
PM replied. Best thing to do to get it all 100% fit is do it all yourself. It's more fun too.
Check my build threads for a Tele pg process.
Old November 16th, 2009, 04:34 PM   #7 (permalink)
Thanks. Did you reply with a PM or email? I don't see either.
Old November 16th, 2009, 06:31 PM   #8 (permalink)
Originally Posted by gsoutherland View Post
...and when I placed the plan over my templates I noticed I somehow got the control plate cavity off a bit.
again, Terry used files from Ed Hawleys CMM'd 67 as the base for the pdf. In the CNC threads Ed posted, he included the pick guard in CAD form. Terry also included the pick guard in the original .DWG CAD version used to generate the pdf. That file can be found with a search here.
If you don't have a CAD program, here's a pdf of Terry's dwg file with page 2 isolating the pick guard. With careful use of the snapshot tool, you should be able to print the guard full scale on one 8.5 x 11 sheet. It matches scaled fender pdfs extremely well.
if you're thinking of making your own bakelite single ply, Ed used xx grade garolite from mcmaster carr. If you want an 8 or 9 (muddy waters) hole, let me know and I can give you a pretty good idea of where the extra holes go.
Old November 17th, 2009, 12:04 AM   #9 (permalink)
Thanks, Casual Reader. That was very helpful. I cropped the file down and saved it as a pdf in case anyone else can use it.
Old November 17th, 2009, 02:06 AM   #10 (permalink)
preeb's Avatar
Email. Check your spam folder maybe.
Old November 17th, 2009, 09:18 AM   #11 (permalink)
Yep, it was in the spam folder. Thanks for sending.
Blueprint abbreviations: What does PL mean? gsoutherland Tele Home Depot 2 November 10th, 2009 03:55 PM
tele blueprint jelleast Telecaster Discussion Forum 18 January 12th, 2008 05:00 PM
pickguard blueprint 69 thinline nokaster Telecaster Discussion Forum 13 June 20th, 2007 03:39 PM
Hey Sabby (tdowns... et al) JoeAArthur Tele-Tech 16 July 20th, 2005 09:34 PM
Guitar Instructional Video.(TDowns) Simpleman73 Bad Dog Cafe 2 May 19th, 2004 12:28 AM
