Old November 15th, 2009, 01:02 PM   #1 (permalink)
impact of compound radius necks on action?
Just wondered if anyone had experience of how compound radius such as warmoth impact the action, and how it affects setup - I imagine height adjustable saddles help?
Thanks.
loog is offline   Reply With Quote
Old November 15th, 2009, 01:07 PM   #2 (permalink)
axmaker's Avatar
Thanks.
I don't know about Warmouth, but I built one with 10" to 12". I needed to use an LSR nut with a tune-o-matic bridge. I was the only option, but it played really nice. Good luck.
Here is the build thread for it:
http://www.tdpri.com/forum/telecaste...ele-build.html
Old November 15th, 2009, 05:17 PM   #3 (permalink)
RomanS's Avatar
Theoretically, a compound radius should allow for a lower action than a straight radius - think about it:
The strings on a guitar neck follow the sides of a cone (not a cylinder) - because they are spaced more narrowly at the nut than at the bridge; and a compound radius fretboard is also the side of a cone; a straight-radiussed fretboard is part of the side of a cylinder (which, as said, the strings are not); so, on an ideal compound radius, the strings will exactly follow the shape of the fretboard at the same distance all the way along the neck - on a straight radius there's no way that this would be geometrically possible!
Taking theory aside, I have two Warmoth necks with 10-16" radius, and could set my action REALLY low without any noise, I wanted to (I set mine slightly higher than what would be possible, because I find that a higher action makes "gripping" the strings easier with your fingertips when doing string bends).
Old November 15th, 2009, 05:33 PM   #4 (permalink)
woodman's Avatar
the compound radius necks i've used give a lot better action up past the 12th fret. dunno why that's so, but it's been the case with all four i've tried.
Old November 15th, 2009, 06:07 PM   #5 (permalink)
Mojotron's Avatar
Right - what RomanS mentioned, the strings from the bridge to nut make the shape of the side of a cone. So, if the fretboard matches the string location more closely you should be able to get better action.
I have a number of Warmoth 10-16 necks too and what I notice (comparing to other necks with straight radius from 12" to 16") is that the lowest available action is really a factor of how good of a fret-level job you have.
So - I would say, as long as you have a straight radius of 12" or greater - it makes little difference.
Mojotron is online now   Reply With Quote
compound radius question spyderxxx Tele Home Depot 33 October 26th, 2009 09:33 PM
Warmoth Compound Radius Necks KY-TwangBanger Telecaster Discussion Forum 12 October 13th, 2009 10:26 PM
Warmoth compound radius necks mark123 Tele-Tech 8 August 31st, 2008 05:16 PM
Compound Radius TheSonicBlue Tele-Tech 6 May 20th, 2006 09:12 PM
Warmoth's Compound Radius Shnook Tele-Tech 2 November 30th, 2003 04:46 AM
