Old November 13th, 2009, 12:31 AM   #1 (permalink)
Ancient Kauri teles
I am going to put together 2 guitars one tele 12 string one other deign from Ancient Kauri. I received 2 cuts of it today measuring 600mm x 400mm x 50mm. My idea is if i do 2 teles ones definately a 12 string maybe hollow, the other a tele junior or a LPS junior style or even a jazzmaster type. I am half way through a chambered Baritone strat and when finished i will start on a tele.
The timber is rough at the moment but has some nice flame in it.
Any ideas or advice much appreciated.
tonyw is offline   Reply With Quote
Old November 13th, 2009, 01:50 AM   #2 (permalink)
No ideas or advice but years ago I started a precision body in kauri but ran out of money so a friend took it over and it turned out pretty well. It wasn't old kauri, I got it from a sawmill near us when I lived in NZ. It was nice wood to work with.
Clive Hugh is offline   Reply With Quote
Old November 13th, 2009, 02:04 AM   #3 (permalink)
G'day Clive
they now dont sell the new Kauri so it would be a nice get from back then.
I went with the Ancient Kauri because of some guitars i had seen built with this timber. The 2 slabs of timber i have they weight is approx 6.5 kg per piece but theres alot to come off and out so they should be reasonable in weight by the time they take a guitar shape.
cheers
Tony
Old November 13th, 2009, 03:56 AM   #4 (permalink)
Nick JD's Avatar
It's okay to work with - the only things I would add are that it's got almost no strength across the grain because there's no sap in it. You can snap your offcuts with your fingers. And fully dry it has a high moisture content - must be something to do with its age.
And it needs sealing - eats up finish and never stops asking for more.
If you want the "whitebait" shimmer in the finish, go all the way up to 1200 grit before finishing, and you must always have clean hands because it loves skin oils.
Old November 13th, 2009, 04:43 AM   #5 (permalink)
G'day Nick
thanks for the advise. I always wear cotton gloves after a naptha wipe down 1st up then dont get my hands on the timber or finish again until i have it done.
One pieces has the white bait shimmer the other is more red/brown with a slight crack running with the grain. I have a bucket of tru oil here and the sealer, also wood filler, it reminds me a bit of mahogony but the grain seems tighter. Its rough sawn timber right now so will see how it looks after i get about it a bit with some sanding.
Old November 13th, 2009, 06:44 AM   #6 (permalink)
preeb's Avatar
How can a guy from Israel get hold of a few blanks of Ancient Kauri from the land down under?
preeb is offline   Reply With Quote
Old November 13th, 2009, 08:16 AM   #7 (permalink)
jkingma's Avatar
preeb... I have no trouble getting it in Canada, so you should be able to get it shipped to Israel.
tonyw... I seldom put a pickguard on a Kauri guitar so I attach my templates with double sided tape, (cuz you have nothing to cover the screw holes with). So you have to be really careful removing them otherwise you'll rip up a lot of wood fibers with the tape. Imagine ripping a piece of duct tape off a block of balsa wood.
Old November 13th, 2009, 03:44 PM   #8 (permalink)
preeb: contact Ancient Kauri kingdom in New Zealand they were more than helpful but it takes awhile up to 25days for it to even get to Australia. http://www.ancientkauri.co.nz/
jkingma: Excellent advice thanks for that and i dont think i will be using a pickguard. I notice that the timber will crack etc which after 55000yrs in a swamp i think i would as well. By the way your Kauri guitars look superb.
Heres a pic of the mock up of the Baritone strat i am putting together at the moment and as soon as its finished i will start the kauri.
Old November 14th, 2009, 01:15 AM   #9 (permalink)
preeb's Avatar
Thanks tonyw, I'm on it.
Old November 14th, 2009, 01:58 AM   #10 (permalink)
Nick JD's Avatar
Gil! The Land Down Under is Australia! You're thinking of The Land of the Long White Cloud aka Aotearoa ... New Zealand.
Like the UK, while not being too partcular about our borders, we like you Northerners to at least try not to blur our identities .
BTW shane "at" ancientkauri.co.nz will sort you out. He's a nice guy.
Old November 14th, 2009, 02:32 AM   #11 (permalink)
Too funny.... but ya might have ta be an Aussie ta get it
And Shane also Helen are great
Old November 14th, 2009, 03:52 AM   #12 (permalink)
Borders !!!
There is a large bit of the Pacific Ocean called the Tasman Sea between us.
chezdeluxe is offline   Reply With Quote
Old November 14th, 2009, 09:12 AM   #13 (permalink)
I have a sneaky idea that the ancient kauri is stuff dragged out of a swamp where it has been for a loooong time. I'm surprised you say new kauri is not available, I thought they were selectively logging it and getting it out by helicopter. NZ is not the only source of kauri, there are other related species in the pacific islands which they use for boat building.
Old November 14th, 2009, 10:29 AM   #14 (permalink)
originalmatthew's Avatar
I've built a couple of guitars out of ancient kauri. It is indeed swamp wood according to the US importer. http://www.ancientwood.com They have some great finishing tips on the site as well. The guitar on my avatar is kauri! I have not experienced the weakness mentioned, but be prepared to sand until your fore arms look like popeye's. It's beautiful stuff, can't wait to see the guitars you make from it!!
Let someone else do the white paint job!
originalmatthew is offline   Reply With Quote
Old November 14th, 2009, 02:52 PM   #15 (permalink)
been in the bog for from 30,000 to 55,000 years according to carbon dating they teel you about on all the literature they sent with it. New Kauri is protected.
Old November 14th, 2009, 02:56 PM   #16 (permalink)
I love the look of this stuff, one of the blanks looks like a white hot bushfire, how ironic that i will be doing some work on this guitar near Marysville which was wiped out during the bushfires.
Looks better in realtime but heres a pic
Old November 14th, 2009, 03:37 PM   #17 (permalink)
jkingma's Avatar
Here are a couple of my favorite looking pieces that I've used.
Old November 14th, 2009, 04:52 PM   #18 (permalink)
Wow John
those are fantastic, i love the guitar with the Bigsby, reminds me of a rick and a gretch corvette combo. My idea is for one tele or a LPS shape is a single pup at the bridge, i have an old ultrasonic pickup here that although its a neck pickup i might try it in the bridge, i also thought about the filtertrons for the 12 sting as i have access to a pair.
Old November 15th, 2009, 03:17 PM   #19 (permalink)
preeb's Avatar
So sorry... my mistake.
I'll rephrase:
How can a guy from Israel who doesn't know the difference between down under and Aotearoa get hold of a few blanks of Ancient Kauri from the Land of the Long White Cloud ?
I sent an email his way. No reply yet but the night is still young.
Old November 15th, 2009, 10:45 PM   #20 (permalink)
he probably has a bus load of tourists going through the shop
kiwitele is offline   Reply With Quote
Old November 16th, 2009, 02:05 AM   #21 (permalink)
I'll rephrase:
He will get back to you just may take a day or 2
Old November 16th, 2009, 02:09 AM   #22 (permalink)
Ahh your from Rotorua havent been there since i toured through in the 70's. 1st thing that grabbed my attention was the smell then the place i was staying had hot thermal bathes and hot kiwi lasses, i have fond memories of Rotorua.
Old November 16th, 2009, 03:28 AM   #23 (permalink)
same smell, same hot pools, but the hot lasses have moved on..... not much Kauri here either, plenty of radiata pine though
Ancient Flute - pentatonic scale Leon Grizzard Bad Dog Cafe 3 June 24th, 2009 10:28 PM
Ancient Kauri wood originalmatthew Tele Home Depot 13 June 3rd, 2009 07:54 AM
Ancient Teisco, fried PT... Hep me rhonda? FiddlinJim Shock Brother's DIY Amps 9 May 2nd, 2009 06:08 PM
Ode to My Tube -- Ancient Instrumental Skully Twanger Central 3 December 31st, 2008 06:22 PM
Ancient Details... Ronkirn Telecaster Discussion Forum 6 August 10th, 2005 05:52 PM
