Old November 12th, 2009, 12:56 PM   #1 (permalink)
jrich99's Avatar
Show me your Esquire, Broadcaster, Nocaster, and other blackguard builds
I am planning on taking on my first build, and I think I want to build a Broadcaster. If anyone has done one, I'd like your pictures and comments.
jrich99 is offline   Reply With Quote
Old November 12th, 2009, 06:28 PM   #2 (permalink)
OK I'll Play. Broadcaster - Mark Jenny body, All Parts TMOC neck, Duncan Antiquity bridge pup, Dimarzio Twang King neck pup. Hardware I took off of a Road Worn Tele.
Broly is offline   Reply With Quote
Old November 12th, 2009, 06:32 PM   #3 (permalink)
jrich99's Avatar
Nice...What method did you use to age the fretboard, or is that natural wear?
Old November 12th, 2009, 06:43 PM   #4 (permalink)
I had someone spray the neck for me with a tinted nitro and they added some fingerboard wear that wasn't very convincing to me. Thin chicken scratch kind of wear. I thought I could do a better job myself so I sat down with Nacho's Blackguard book as a guide and with a lot of patience and careful sanding I think it came out pretty authentic looking.
Old November 12th, 2009, 10:26 PM   #5 (permalink)
mijstrat72's Avatar
I love these "show me" threads! This is my first homebuild! 50+ year old pine from an old shelf I found in the bottom of an old grocery store. Built with a handdrill, bandsaw, a dremel and some sandpaper.
The Blues Jr. behind was my actual first jump into wood working, solid well seasoned birch cab with some cedar front baffle pieces for "flare". Both are 100% nitro finishes.
This Esquire is SOOO resonent you can feel every vibration throughout the entire guitar. It's very cool to play and sounds awesome. The rest of my guitars now sit in wait. The output jack is hanging out in this pic because it took forever for the jackplate to show up.
I managed to get one more piece from this shelf, so I may be building another guitar someday soon. It was very fun the first time around.
"I've always considered myself a hobbyist"
mijstrat72 is offline   Reply With Quote
Old November 13th, 2009, 12:17 AM   #6 (permalink)
jrich99's Avatar
From the picture, I actually thought it looked pretty good. Do you have the Blackguard book?
Old November 13th, 2009, 12:37 AM   #7 (permalink)
How'd you do the neck pocket with no router?
Joefaity is offline   Reply With Quote
Old November 13th, 2009, 10:57 AM   #8 (permalink)
Goluphi's Avatar
Very carefully...
Goluphi is offline   Reply With Quote
Old November 13th, 2009, 11:01 AM   #9 (permalink)
mijstrat72's Avatar
My dremel with one of the fast cut bits dremel offers, and two very steady hands!
I drilled a bunch of holes into each area to be routed out, making sure to stay a bit shallow with the drill bit, then went back in with the dremel to do the detail work, here's a sort of "in progress" shot
The neck pocket turned out great and is perfectly snug. Here's another shot of the procedure as I have just about finished up the neck pocket;
Once I was satisfied with the dremeling I went to it with some coarse sand paper and a spare chunk of wood left over from cutting out the body. I used a straight piece of metal stock layed over the top of the body, and a machinists rule to measure pocket depth. Worked out great, but a little time consuming...but for me, it was about the journey.
Old November 13th, 2009, 11:17 AM   #10 (permalink)
jkingma's Avatar
jkingma is online now   Reply With Quote
Old November 13th, 2009, 11:42 AM   #11 (permalink)
bmgblues's Avatar
Big Piney
This Tele used a pinemart body from Marty. The neck is a Musikraft deep U hand rolled by me with Budz pups. Its a killer!
bmgblues is offline   Reply With Quote
Old November 13th, 2009, 04:24 PM   #12 (permalink)
Yes, I actually used the Blackguard book as a reference. It has some amazing photos of detail.
Old November 13th, 2009, 09:47 PM   #13 (permalink)
newtwanger's Avatar
Done to '51 spec except for the double cut bridge. Soon to get a neck pickup.
newtwanger is offline   Reply With Quote
Old November 14th, 2009, 03:16 PM   #14 (permalink)
olaftheholy's Avatar
Can't get enough of this one,'51 piner, G.Y. pickups, Rutters alu bridge al/br/br barrel set teams up nice with that hotrodded '69 super.
Gear:Bunch of teles,strats and other casters--> CMW-amps bOOOster-->tuner-->ts808HW-->Keeley looper-->ts9dx-->MXR 6 band-->Line6 rotomachine-->CMW-amps modded (fmi)'69 Super Reverb-->CR8_18watt 212 combo
olaftheholy is offline   Reply With Quote
Old November 15th, 2009, 07:08 PM   #15 (permalink)
jrich99's Avatar
What type of wood am I best off using for the body?
Old November 15th, 2009, 07:15 PM   #16 (permalink)
Mark-00255's Avatar
My first build - Cedar/Maple chambered body; Bill Lawrence Keystones; Wilky compensated saddles and bridge; 4-way switch ...
Mark-00255 is offline   Reply With Quote
Old November 15th, 2009, 07:42 PM   #17 (permalink)
VENDOR
Southern Ill Electrics's Avatar
Started missing this one @ the time a applied the UPS label on the shipping box and sealed it shut.................
Got started on what I hope will be one for myself recently..........
Pinebody,Big fatty neck, Lollar P-90 and a 3 way.....Should be a sweet axe.
Jeffro' at Southern Ill Electrics
618-643-2406/618-308-0223
God Bless Les and Leo.
Southern Ill Electrics is online now   Reply With Quote
Choose the next "Tribute" tele, esquire, broadcaster, nocaster I build! needfortweed Telecaster Discussion Forum 74 September 24th, 2009 06:20 PM
Ash builds, Esquire and Nocaster 1950 & 51 Scatter Lee Tele Home Depot 105 August 2nd, 2009 09:34 PM
ex-esquire "OJ" is reborn a blackguard broadcaster! vanguard Telecaster Discussion Forum 6 December 13th, 2008 07:08 PM
tele/esquire lover builds a superstrat appar111 Stratocaster Discussion Forum 5 January 23rd, 2008 04:23 PM
Blackguard/Broadcaster Project Rich_W Tele-Tech 1 July 24th, 2007 02:16 PM
