Old November 7th, 2009, 05:50 PM   #1 (permalink)
Ferrules in a painted body - install
I want to install vintage style ferrules in an already drilled and painted body.
The holes are currently 3/16". How could I make the holes bigger without damaging the paint? The holes need to be 3/8" wide and 3/8" deep. The holes are already deeper than that. Will there be enough wood to support the pull of the strings?
I want to install these:
http://www.allparts.com/Nickel-Strin...p-0187-001.htm
Thanks for any help!
Fiver is offline   Reply With Quote
Old November 7th, 2009, 09:14 PM   #2 (permalink)
jwells393's Avatar
You could probably use a 3/8 in. Forstner bit without damaging the paint. The sharp edges shown here can slice through the paint without chipping.
Just how much deeper than 3/8 in. are the holes now. I use similar ferrules I get from StewMac. I like to drill the holes a little deeper than 3/8 in. then bevel the holes a little like this.
If the holes are too deep now, just glue in some 5/16 in. dowel and re-drill. If you decide to re-drill the ferrule holes, I suggest following the procedure show in posts 38 and 39 of the following thread.
http://www.tdpri.com/forum/tele-home...line-**-4.html
Old November 7th, 2009, 09:38 PM   #3 (permalink)
Ahhh! you may have hit on something. I may need to plug it, then re-drill it. I will need a template or way to accurately space the holes, i.e. scaling system / digital readout.
I may have to contemplate this a bit more. Nice idea with beveling though it would hurt the paint in my case.
Thanks for the spark* (of an idea)
Old November 7th, 2009, 10:00 PM   #4 (permalink)
Buckocaster51's Avatar
Masking tape over the holes/paint before you drill. It will help to minimize chipping.
Old November 8th, 2009, 08:50 AM   #5 (permalink)
jwells393's Avatar
The procedure I linked to at the end of my previous post accounts for the spacing.
Old November 8th, 2009, 09:02 AM   #6 (permalink)
A step drill will have a 1/4, 5/16, 3/8 inch drill bit in that order on one bit in steps . Harbor Freight has them if you have one nearby. The 1/4" drill would follow your 3/16 hole, and then just keep going until you get the 3/8 cut started some. Then I'd go down deeper with a 3/8 forstner bit.
Old November 8th, 2009, 12:04 PM   #7 (permalink)
if the holes are too deep you could always put in a small piece of dowel to make it proper depth. it would in invisible on the outside.
Guitartom_ca is online now   Reply With Quote
Where can I get my body repainted or painted over? Ignatius Finely Finished 6 September 5th, 2009 02:51 PM
I'm sick, I just chipped my newly painted body GhostofJohnToad Tele-Tech 26 May 18th, 2008 02:21 PM
Recently purchased a painted body and neck will not fit? digitaldrummer Tele-Tech 2 April 23rd, 2008 07:22 PM
Painted body enamel Duh!!! dave55 Tele-Tech 12 October 25th, 2006 05:28 AM
Do you have any pics of painted flames on a Tele body? stegre Telecaster Discussion Forum 6 October 27th, 2004 03:58 PM
