Old November 6th, 2009, 10:04 PM   #1 (permalink)
Might Mite neck question
My Mighty Mite neck just arrived.
The fit, finish, frets all look pretty good for an under $100 neck.
My question is about the neck adjustment plug. I think Fender uses walnut or something similar. The one in the Might Mite appears to be...ugh...plastic. I've looked at it under 30X magnification and I can see no wood grain but that could be because of the finish.
Doe's anyone know if, in fact, they use plastic?
I looks like when the head radius was sanded, a tiny amount of the material melted into/bonded to/stained the maple (We're talking about an area about 1mm square. To make it perfect I'm fairly sure I can scrape it down and refinish.
mcgeorgerl is offline   Reply With Quote
Old November 6th, 2009, 10:24 PM   #2 (permalink)
Ironwolf's Avatar
It is plastic.
Oderint Dum Metuant - Nero Caesar
Ironwolf is offline   Reply With Quote
Old November 6th, 2009, 11:07 PM   #3 (permalink)
I know I can be a bit picky at times and I'm just not thrilled about the plastic.
If I had known, I probably would have passed but I'll console myself with knowing that it's a decent neck to start with.
I can't figure out why they would "cheap out" on the plug when wood could not possibly cost that much more.
Old November 7th, 2009, 12:26 AM   #4 (permalink)
My guess would be that it's easier to mold plastic than to cut and drill wood. Just my guess.
Joefaity is offline   Reply With Quote
Old November 7th, 2009, 12:45 AM   #5 (permalink)
You won't have to worry unless someone approaches your guitar with a 30x microscope!
I know all about being picky, but really, c'mon now. For $100, you have to let it go.
John R. Frondelli
jrfrond is offline   Reply With Quote
Old November 7th, 2009, 01:14 AM   #6 (permalink)
edgemarc's Avatar
Your the only one it's gonna bug, but bug you it always will.
edgemarc is offline   Reply With Quote
Old November 7th, 2009, 05:14 AM   #7 (permalink)
C'mon relax .The binding on a Martin D45 is plastic.
chezdeluxe is offline   Reply With Quote
Old November 7th, 2009, 10:43 AM   #8 (permalink)
VENDOR
Southern Ill Electrics's Avatar
I've used them on some builds........All needed some work,but so have all the other necks I have used...........Once you get it finished and playing well, I doubt it'll matter.
Jeffro' at Southern Ill Electrics
618-643-2406/618-308-0223
God Bless Les and Leo.
Southern Ill Electrics is online now   Reply With Quote
Might mite neck danyboy Tele Home Depot 2 June 18th, 2009 12:43 PM
Got my Might Mite neck today!! boneyguy Tele Home Depot 10 April 21st, 2009 07:29 PM
Nut slots on mighty mite neck? Guitartom_ca Tele-Tech 2 April 7th, 2008 05:50 PM
Mighty Mite Neck Enjoicube Tele-Tech 9 August 23rd, 2007 05:26 PM
Mighty Mite - question about neck pocket holgaguy Stratocaster Discussion Forum 2 January 10th, 2007 10:47 AM
