Strat neck on Tele body - question
Hi.
I'm looking at installing a S-style neck on a T-style body. (not my first choice, but it's what I have to work with) Would it be better to flatten the slight radius on the end of the heel, add a small radius to the pocket, or just leave them both the way they are ? The body isn't cut yet, so I have leeway there. I understand that this is probably not the brightest of questions, but I'm just starting out and it's something that I would be better off being sure of. Thanks in advance. |
I've done it twice... once each way.
If you're going to have a pickguard then square off the neck to match the p/g cutout. If you are not using a pickguard then rout the pocket to match the neck. That's the way I did it. BUT it also depends on what end of the neck your truss rod adjusts.
Creator of Fine Sawdust and Expensive Kindling. |
Keep in mind, either of those two options will alter the scale length slightly. It would be better to mount the neck without alterations and make a custom pickguard to cover the small gaps between the pocket and neck.
Oderint Dum Metuant - Nero Caesar |
#6 (permalink) | ||
I think you mean it may alter where the bridge needs to be placed. If I understand, the body is being made from scratch, so the bridge can be placed where it needs to be without having to match up with pre-existing holes. Quote:
+1 ...it keeps the mix and match vibe.
if you were to sand it flat, you'd be taking about 5/64ths (2mm) off... a difference that saddle adjustment should be able to handle without moving the bridge. It doesn't technically change the scale of the guitar, but it does change where the pickups are located in relation to that scale... by 2 mm. to get pedantic... the center line of the tele neck pickup is between the 24th and 25th fret position. The space between those 2 frets is .357" - the p'up center line is .093 from the 24th. Moving the scale changes it from roughly 1/4 the spacing to nearly 1/2 the spacing - centered. (I warned you it was pedantic) would you hear the difference? would it place the p'up where you'd notice more harmonic canceling? probably not, but I still like the look of the gap better. |
| Strat neck + Tele body (pickguard question) | NewGuy410 | Tele Home Depot | 10 | May 7th, 2009 09:27 PM |
| Strat Neck on Tele Body? | pompeii0 | Telecaster Discussion Forum | 11 | July 4th, 2008 10:42 PM |
| Strat neck in Tele body ?? | cuffb | Telecaster Discussion Forum | 9 | October 29th, 2007 12:00 PM |
| Strat Neck, Tele Body | MattyB | Tele-Tech | 10 | July 19th, 2007 09:26 PM |
| Neck Transplant - Strat Neck & Tele Body - Frankenstein! | km.3000 | Tele-Tech | 15 | November 30th, 2005 11:32 AM |
